Need to convert C to PBP
Results 1 to 4 of 4
    Apr 2011
    Kent, UK
    Default Need to convert C to PBP
    I am trying to write some code in PBPpro from an example in C.
    I have got so far but am not familiar with C.
    They give the packet structure and an example, but I cannot decipher what the code is doing before retrieving a value from a lookup table, and hopefully someone will be able to assist me here.
    Any help greatly appreciated.
    By the way, attachment is copyright Atomos Pty, Australia.
    CHKSUM		VAR LONG
    VALUE		VAR LONG
    COMMAND		VAR WORD
    SIZE		        VAR WORD
    TEMP_W		VAR WORD
    TEMP_B		VAR BYTE
    BUFFER		VAR BYTE [21]
    SEND:		 SIZE = $14
    			COMMAND = 0
    			VALUE = 1
    			BUFFER [1] = SIZE.BYTE1
    			BUFFER [2] = SIZE.BYTE0
    			BUFFER [3] = COMMAND.BYTE1
    			BUFFER [4] = COMMAND.BYTE0
    			BUFFER [5] = $FF
    			BUFFER [6] = $FF
    			BUFFER [7] = $FF
    			BUFFER [8] = $FF
    			BUFFER [9] = $FF
    			BUFFER [10] = $FF
    			BUFFER [11] = $FF
    			BUFFER [12] = $FF
    			BUFFER [13] = VALUE.BYTE3
    			BUFFER [14] = VALUE.BYTE2
    			BUFFER [15] = VALUE.BYTE1
    			BUFFER [16] = VALUE.BYTE0
    			SOMEVALUE = ' <insert converted C code here >
    			GOSUB LOOK_CHKSUM
    			BUFFER [17] = CHKSUM.BYTE3
    			BUFFER [18] = CHKSUM.BYTE2
    			BUFFER [19] = CHKSUM.BYTE1
    			BUFFER [20] = CHKSUM.BYTE0
    			FOR TEMP_W = 1 TO SIZE
    				TEMP_B = BUFFER [TEMP_W]
    				HSEROUT [TEMP_B]
    			NEXT
    			GOTO MAIN_LOOP
    LOOK_CHKSUM:
                            LOOKUP2 SOMEVALUE,_
    				[$0000, $1021, $2042, etc ], CHKSUM
    Apr 2011
    Kent, UK
    Default Re: Need to convert C to PBP
    Dohh... Here is the attachment.
    Jun 2010
    Venezuela
    hi timmers, you example is for calculate cyclic redundancy check (CRC16). look here two example one using Vb6 the another one with PBP. i use both
    http://www.picbasic.co.uk/forum/showthread.php?t=16735
    here explain how to that:
    http://en.wikipedia.org/wiki/Computation_of_CRC
    I am still struggling to learn C myself so what I say here MAY BE TOTALLY INCORRECT.
    const u16 crc_16_table[0x100]
    const u16 = dataType , crc_16_table = varName, [0x100] = startMemLocation, & this can be put into program memory with PROGMEM command at least in arduino.
    HTH
