SD card file date stamp
Results 1 to 3 of 3
    Dec 2009
    Canada
    Default SD card file date stamp
    Hello All,
    Could someone explain please how to use correctly SDFS.PBP include file in regards of correct handling file date. Everything seems to be working for me except of that when I create a file or open one for write, the date assigned to file (as I see it when then open the SD card on PC) is always 1992 instead of 2012, so I have to actually assign the value 12+20 in order to get 2012 when I then open card on Windows computer. The year is being read from RTCC which keeps two digits. I tried to set RTCC to 2020, 2039 year, etc. and if I add 20 before assigning this to the file date, everything seems to be working ok but I am not comfortable with this because I do not know why this happens
    This is how I read RTCC:
    READ_RTC:
    I2CREAD RTCC_SDA, RTCC_SCL, RTC, SEC_REG, [sec,mins,hr,day,date,mon,yr]
    YR_T = yr & %11110000
    YR_T = YR_T>>4
    YR_O = yr & %1111
    YR_O = YR_O+10*YR_T 'here we must have 12 for this year
    Than I record in file:
    Gosub FSinit ' INIT card
    ARRAYWRITE FAT_Filename, ["LOG TXT"]
    ' Set file time to CURRENT TIME and date
    FAT_seconds = 0
    FAT_minutes = MIN_O
    FAT_hours = HR_O
    FAT_day = DATE_O
    FAT_month = MON_O
    FAT_year = YR_O + 20 'HERE I HAVE TO ADD 20. NOT SURE WHY!
    ' Open a file for write
    FAT_mode = "a" ' Append mode
    Gosub FSfopen ' Open file pointed to by Byte array FAT_FileName
    ' Write to file
    This way
    ' ARRAYWRITE FAT_src, [HEX2 DATE,"-", HEX2 MON,"-",HEX2 YR, ",", _
    Or this way, no difference
    ARRAYWRITE FAT_src, [HEX2 DATE,"-", HEX2 MON,"-",dec2 YR_o, ",", _
    HEX2 HR, ":", HEX2 MINS,","]
    FAT_count = 15
    Gosub FSfwrite
    Maybe zero year in FAT is 1980? same value appears as 1992 in file change date and as 12 in the record inside the file so it has to be incremented by 20 to become 2012 in the file time stamp
    Please advise
    Thank you very much!
    Default Re: SD card file date stamp
    You can look this test code over. I have the serial output for debugging.
     'FL PIC18F4550
    'TEST RTC TO SD CARD
    '18F4550
    '02/28/09
    DEFINE OSC 48
    @ __CONFIG   _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    @ __CONFIG   _CONFIG1H, _FOSC_HSPLL_HS_1H
    @ __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
    @ __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_OFF_3H
    @ __CONFIG    _CONFIG4L, _LVP_OFF_4L & _ICPRT_OFF_4L &_XINST_OFF_4L
    ' Alias PIC pins and registers for SD/MMC card
    SD_WE        Var    PORTA.4    ' SD card write protect
    SD_WE_TRIS    Var    TRISA.4    ' SD card write protect direction
    'SDI        Var    PORTB.0    ' SPI data in SD #7
    'SDI_TRIS    Var    TRISB.0    ' SPI data in direction
    SDI        Var    PORTB.2    ' SPI data in SD #7
    SDI_TRIS    Var    TRISB.2    ' SPI data in direction
    SCL        Var    PORTB.1    ' SPI clock  SD #5
    SCL_TRIS    Var    TRISB.1    ' SPI clock direction
    SD_CS        Var    PORTB.3    ' SD card chip select SD #1
    SD_CS_TRIS    Var    TRISB.3    ' SD card chip select direction
    SD_CD        Var    PORTB.4    ' SD card detect
    SD_CD_TRIS    Var    TRISB.4    ' SD card detect direction
    SDO        Var    PORTC.7    ' SPI data out   SD #2
    SDO_TRIS    Var    TRISC.7    ' SPI data out direction
    ON INTERRUPT GOTO T_INT
    INTCON = %10010000
    CNT    VAR    WORD
    CNT = 0
    BOOT:
    CLEAR
    XCNT    VAR    LONG
    OCNT    VAR    BYTE
    OCNT = 0
    TCNT    VAR    BYTE
    TCNT = 0
    Z    VAR    LONG
    Z = 0
    GPS    VAR    BYTE[53]
    RTC_STR    VAR    BYTE[25]
    N1    VAR    BYTE[4]
    N2    VAR    BYTE[3]
    TEMPERATURE    VAR    BYTE
    T_ONES        VAR    BYTE
    T_TENS            VAR    BYTE
    TEMPERATURE = 99
    T_TENS = TEMPERATURE/10
    T_ONES = TEMPERATURE-(T_TENS*10)
    'RTC DEFINES
    DS_SCL    VAR    PORTD.1
    DS_SDA    VAR    PORTD.0
    RTC    CON    %11010000
    'Setting the RTC so we can get out 1Hz tick output
    ' -------------- RTC definitions -----------------
    SecReg CON $00 ' seconds address (00 - 59) ' MSB of SecReg must be set to a 0 to enable RTC
    ContReg CON $0E ' control register
    cntrl CON %00000000 ' sets the SQW/OUT to 1Hz pulse, logic level low
    ' The variable below holds the values entered:
    ' entered by the user
    sec VAR BYTE ' seconds
    MINs VAR BYTE ' minutes
    hr VAR BYTE ' hours
    day VAR BYTE ' day
    date VAR BYTE ' date
    mon VAR BYTE ' month
    yr VAR BYTE ' year
    SEC_O    VAR BYTE
    SEC_T    VAR BYTE
    MIN_O    VAR BYTE
    MIN_T    VAR BYTE
    HR_O    VAR BYTE
    HR_T    VAR BYTE
    'ALARM VARIABLES
    A_MINs VAR BYTE ' minutes
    A_hr VAR BYTE ' hours
    I2CWrite DS_SDA, DS_SCL, RTC, ContReg, [cntrl]
    ' Include the SD/MMC subroutines
    Include "SDFS.BAS"
    SDC_UseHardSPI = FALSE    ' Use hardware SSP port for SPI.
    ADCON1 = 15        ' All I/O pins digital
    TRISD =%00000000
    PAUSE 1000
    Serout2 PORTC.6, 16572, [ "MACKRACKIT ", $d, $a]
    Serout2 PORTC.6, 16572, [ "RTC ", $d, $a]
    Pause 1000
    '###GOSUB SET_RTC
    HIGH PORTD.7
    CHECK:
    IF CNT = 600 THEN
    CNT = 0
    GOSUB RUN
    GOTO CHECK
    RUN:
    TOGGLE PORTD.7
    I2CRead DS_SDA, DS_SCL, RTC, SecReg, [sec,MINs,hr,day,date,mon,yr]
    Serout2 PORTC.6, 16572, [ "RUN ", $d, $a]
    Serout2 PORTC.6, 16572, [ "TIME ", HEX2 hr, ":", HEX2 MINs, ":", HEX2 sec,$d, $a]
    Serout2 PORTC.6, 16572, [ "DATE ", HEX2 mon,"-",HEX2 date,"-",HEX2 yr,$d, $a]
    Serout2 PORTC.6, 16572, [ "INT COUNT ", DEC CNT,$d, $a]
    PAUSE 1000
    SEC_T = sec & $70
    SEC_T = SEC_T>>4
    Serout2 PORTC.6, 16572,["SEC_T  ",DEC SEC_T, $d, $a]
    SEC_O = sec & $0F
    Serout2 PORTC.6, 16572,["SEC_O  ",DEC SEC_O, $d, $a]
    MIN_T = MINs & $70
    MIN_T = MIN_T>>4
    Serout2 PORTC.6, 16572,["MIN_T  ",DEC MIN_T, $d, $a]
    MIN_O = MINs & $0F
    Serout2 PORTC.6, 16572,["MIN_O  ",DEC MIN_O, $d, $a]
    HR_T = hr & $70
    HR_T = HR_T>>4
    Serout2 PORTC.6, 16572,["HR_T  ",DEC HR_T, $d, $a]
    HR_O = hr & $0F
    Serout2 PORTC.6, 16572,["HR_O  ",DEC HR_O, $d, $a]
     'GOTO SD_MAIN
    'GOTO RUN
     SD_MAIN:
    TOGGLE PORTD.7
      '  PAUSE 250
       GOSUB SDINIT
        GOSUB SDFILENAME
        GOSUB SDOPEN_W
    GOSUB SD_WRITE
    GOSUB SDCLOSE
     '  GOSUB SD_READ
     'GOTO SD_MAIN
    'GOTO RUN
    SDINIT:
    ' FSInit initializes the card and reads all the preliminary information from it
    Gosub FSInit
    Serout2 PORTC.6, 16572, ["Init: ", Dec FAT_error, " ", Dec SDC_status, " ", Dec SDC_response, $d, $a]
         IF (FAT_error = 6) THEN SD_MAIN
        If (FAT_error != 0) Then Stop
        ' Display card directory
        Gosub FINDfirst        ' Find first file on card
        While (FAT_error = 0)
            Serout2 PORTC.6,16572, [Str FAT_FileName\11, $d, $a]
            Gosub FINDnext    ' Find next file on card
        Wend
       SDFILENAME:
    ' This section defines a specific short (8.3) filename
    '  Note that spaces are use in empty elements and must be upper case for Windows
        FAT_FileName[0] = "G"
        FAT_FileName[1] = "P"
        FAT_FileName[2] = "S"
        FAT_FileName[3] = " "
        FAT_FileName[4] = " "
        FAT_FileName[5] = " "
        FAT_FileName[6] = $30+TCNT
        FAT_FileName[7] = $30+OCNT
        FAT_FileName[8] = "T"
        FAT_FileName[9] = "X"
        FAT_FileName[10] = "T"
    ' Set file time to 8:30:10 and date to 1/1/2008
        FAT_seconds = sec
        FAT_minutes = MINs
        FAT_hours = hr
        FAT_day = date
        FAT_month = mon
        FAT_year = 20+yr
        SDOPEN_W:
        FAT_mode = "A"        ' Write mode
      Serout2 PORTC.6, 16572, ["Open for write Error: ", Dec FAT_error, $d, $a]
    Serout2 PORTC.6, 16572, [ "FILE NAME  ", STR FAT_FileName\11, $d, $a]
    Serout2 PORTC.6, 16572, [ "DISK_fat  ", Dec DISK_fat, $d, $a]
    Serout2 PORTC.6, 16572, [ "DISK_buffer  ", Dec DISK_buffer, $d, $a]
    Serout2 PORTC.6, 16572, [ "SDC_sector_addr  ", Dec SDC_sector_addr, $d, $a]
    Serout2 PORTC.6, 16572, [ "FAT_ccls   ", Dec FAT_ccls, $d, $a]
    Serout2 PORTC.6, 16572, [ "LAST_CLUSTER ", Dec LAST_CLUSTER, $d, $a]
    Serout2 PORTC.6, 16572, [ "FAT_c  ", Dec FAT_c, $d, $a]
    Serout2 PORTC.6, 16572, [ "DISK_maxcls:  ", Dec DISK_maxcls, $d, $a]
        'IF (FAT_error = 10) THEN Stop
     IF (FAT_error = 10) THEN XNAME
        If (FAT_error != 0) Then BOOT 'SD_MAIN
       SD_WRITE:
    ' Write to file
    Z = 0
    'FOR XCNT = 1 TO 33
        FAT_src[0] =$30+HR_T
        FAT_src[1] =$30+HR_O
        FAT_src[2] = ":"
        FAT_src[3] = $30+MIN_T
        FAT_src[4] = $30+MIN_O
        FAT_src[5] = ":"
        FAT_src[6] = $30+SEC_T
        FAT_src[7] = $30+SEC_O
        FAT_src[8] = " "
        FAT_src[9] = " "
        FAT_src[10] = " "
        FAT_src[11] = " "
        FAT_src[12] = " "
        FAT_src[13] = " "
        FAT_src[14] = $d
        FAT_src[15] = $a
        FAT_count = 16
        Gosub FSfwrite
    Z = Z + 1
    Serout2 PORTC.6, 16572, [ "ROLL OVER AT 100000  ", Dec Z," FCNT ",DEC TCNT,DEC OCNT, $d, $a]
    'NEXT XCNT
        Serout2 PORTC.6, 16572, [ "Write ",Dec FAT_error, $d, $a]
        If (FAT_error != 0) Then STOP
    'GOSUB SDCLOSE
    'Serout2 PORTC.6, 16572, [ "DONE ",  $d, $a]
    'STOP
      XNAME:
    'IF O = 10 THEN
    'O = 1
    'T = T + 1
    OCNT = OCNT + 1
    IF OCNT = 10 THEN    'TCNT = TCNT + 1 AND OCNT = 0
    OCNT = 0
    TCNT = TCNT + 1
    IF TCNT = 10 THEN STOP
    GOTO SD_MAIN
        SDCLOSE:
    ' Close file
        Gosub FSfclose
        Serout2 PORTC.6, 16572, [ "Close ", Dec FAT_error, $d, $a]
        SD_READ:
    ' Open a file for read
        FAT_mode = "r"        ' Read mode
    Serout2 PORTC.6, 16572, ["Open: ", Dec FAT_error, $d, $a]
    ' Read and display the whole file
        FAT_count = 1    ' Read 1 byte to buffer at a time
        Gosub FSfread
            Serout2 PORTC.6, 16572, [FAT_dest[0]]
            Gosub FSfread
        Wend
        Serout2 PORTC.6, 16572, [$d, $a, "Read: ", Dec FAT_error, $d, $a]
    SET_RTC:
    yr = $10
    mon = $02
    date = $14
    sec = $00
    mins = $44
    hr = $01
    I2CWrite DS_SDA, DS_SCL, RTC, SecReg, [sec,mins,hr,day,date,mon,yr]
    DISABLE
    T_INT:
    CNT = CNT + 1
    INTCON.1 = 0
    RESUME
    ENABLE
    Dec 2009
    Canada
    Thank you very much for sharing the code, Mackrackit, I see you do the same: FAT_year = 20+yr
