Hi everybody,
I am attempting to interface a PIC16F887 with a PCA9532 LED driver. I've read the PCA9532 datasheet http://www.nxp.com/documents/data_sheet/PCA9532.pdf and I am trying to follow the "Programming Example" on page 14. I am new to the i2c protocol and having problems receiving any response from the PCA9532. I have attached the programming example page and my test code. I will post my schematic shortly.
Any help would be greatly appreciated. Thank you very much!
Code:'**************************************************************** '* Name : i2c comms test with led driver * '* Author : Cody Finden * '* Version : 1.0 * '* Notes : SOFTWARE FOR A 16F887 TO WRITE TO A LED DRIVER * '* : OVER THE I2C PROTOCOL * '**************************************************************** #config __CONFIG _CONFIG1, _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _CPD_OFF & _BOR_ON & _IESO_ON & _FCMEN_ON & _LVP_OFF __CONFIG _CONFIG2, _BOR40V & _WRT_OFF #endconfig DEFINE OSC 20 ANSEL = %00000000 ANSELH = %00000000 TRISA = %00000000 TRISB = %00000000 TRISC = %00000000 TRISD = %00000000 SDA VAR PORTD.3 SCL VAR PORTD.2 led var portc.5 addr var byte INIT: PAUSE 400 'let hardware settle addr = $c0 'PCA9532 i2c address MAIN: I2CWRITE SDA,SCL,ADDR,[$12,$97,$80,$00,$40,$55,$FA,$00,$00] led = 1 'blink led for feedback PAUSE 250 led = 0 pause 250 goto main
