Simple question about "Sound" command
Results 1 to 4 of 4
    Dec 2011
    IO93ok
    Default Re: Simple question about "Sound" command
    I'm thinking this must be in a larger loop structure to keep returning to the routine.
    How about this as an idea only:
    If Temperature > Temp_Up then           ' Above Target temperature
      PORTA.2=0                             ' Deactivate Warm output
      PORTA.3=1                             ' Activate   Cold Output
    SOUND PortA.7, [107,50]
    temp_up = temp_up +5                     'or 10 or whatever
    endif                                    'as long as reset elsewhere
    You need a flag to remember that you've already sounded the alarm.
    AlarmDone VAR BIT
    IF Temperature > TempUp THEN
      PortA.2 = 0
      PortA.3 = 1
      IF AlarmDone = 0 THEN          ' Only activate alarm if not already activated.
        SOUND PortA.7, [107, 50]
        AlarmDone = 1                   ' Alarm has been activated.
      AlarmDone = 0                   ' Temperature is not over the limit, rearm the alarm.
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply !
    The second variant work verry fine. THANK YOU, Mr.Henrik ! As usual, You're a Great Gentleman !
