PIC16LF1939 Configuration Errors
Results 1 to 6 of 6
    Miami, Florida USA
    Default PIC16LF1939 Configuration Errors
    I've been using this 16LF1939 chip for a while. I always configure it with the Melabs U2 programmer software, which is the easy way to do it . Now, I'm trying to set the fuses in the program like this
    @  DEVICE PIC16LF1939
    @  __CONFIG _CONFIG2, _FOSC_INTOSC & _WDTE_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_ON & _CPD_ON & _BOREN_OFF & _CLKOUTEN_OFF
    @  __CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF & _WRT_OFF & _PLLEN_OFF & _STVREN_OFF & _BORV_25 & _LVP_OFF
    And, I'm getting some errors. I'm using PBP2.60c and MPASM. Any ideas of what I'm doing wrong? I suspect the first line is part of the problem.
    P.S. There are two *.inc files for this chip. One in the PBP2-60 directory and another one in the MPASM SUITE directory. Do I need to make any changes to these files?
    Anonymous
    Default Re: PIC16LF1939 Configuration Errors
    1. Drop the DEVICE line and select the device from the IDE (say MicroCode or FineLine).
    2. Comment out the config lines in the *.inc file of the PBP folder.
    HTH,
    Miami, Florida USA
    Thanks, I'll try that. But, does it work by selecting the device from the IDE only? I need to get the HEX file with the full configuration of the chip and the type of chip. I have seen this "@ DEVICE PIC16LF1939" line been used before by people here in the forum, so I don't know why it doesn't work in my case.
    Anonymous
    Because you are using MPASM and
    is for PM.
    Yes it works OK. Don't worry about that.
    It makes sense if your IDE does not support it. For example compiling from Command Line.
    Miami, Florida USA
    Thank you guys. Now, it works fine. There is a "condensed" version of the thread that Dave mentioned that was really helpful.
    http://www.picbasic.co.uk/forum/cont...o-your-Program
    The tricky part (at least for me) to make it work was figuring out that I needed two CONFIG statement lines. One for CONFIG1 and another one for CONFIG2.
    @  __CONFIG _CONFIG1, .......
    @  __CONFIG _CONFIG2, .......
    Anonymous
