PIC16f877-20 to a PIC16f877A I/P Disaster
Results 1 to 18 of 18
    andyf's Avatar
    andyf Guest
    I dont have a zif, its sitting in a solderless breadboard directly in the place where the 16f877 was, I keep trying idea's, swapping them around, reloading the appropriate hex file but still get the error when I verify.
    I am using conventional In circuit programming, hardly any components on the breadboard and smooth voltages.
    What works perfectly for the 877 does not for the 877A.
    Tried erase before write.
    Made sure I have the low-voltage programming pin (RB3) pulled to
    ground when programming the device.
    Above it was suggested about the bootloader, is a bootloader required if using the older in circuit programming or on the 877A must it be used no matter how, just a thought.
    Its doing my head in, got a project on the go and cant store the code in the chip :-(
    Try to program it in-circuit without the crystal connected.
    Try turning off the EPIC verify option. Then see if your code runs as expected.
    Does either work?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    andyf's Avatar
    andyf Guest
    Tried it Bruce and it made no difference, am going to cry soon.
    If you turn OFF the EPIC verify option you still get a "verify" error?
    -Bruce
    tech at rentron.com
  1. PIC16f877 code crosses boundary @800h
    By inventosrl in forum mel PIC BASIC Pro
    Last Post: - 6th April 2009, 23:03
  2. communicating pic18f452 with pic16f877a
    By tamersoss in forum mel PIC BASIC Pro
    Last Post: - 13th July 2007, 20:54
  3. capture/repeat data ?
    By Sam in forum Serial
    Last Post: - 27th November 2006, 04:19
  4. A little DTMF help
    By Travin77 in forum mel PIC BASIC Pro
    Last Post: - 30th May 2006, 02:31
