READCODE Instruction dont'work
Results 1 to 3 of 3
    Sep 2011
    Unhappy READCODE Instruction dont'work
    Hello,
    Just a question on istruction that i have never used before today.
    I need to read a table of Words values stored in program space flash on my pic.
    So i need to user READCODE to retrieve data from a table of DW made in Assembly
    where i have stored a table of values.
    But when i try to compile a very simple program that use the istruction READCODE
    i will get back this errors:
    PICBASIC PRO(TM) Compiler 2.60C, (c) 1998, 2011 microEngineering Labs, Inc.
    All Rights Reserved.
    ERROR: Unable to execute mpasmwin.Error[113] C:\PBP\PBPPIC14.LIB 449 : Symbol
    not previously defined (EEADRH)
    Error[113] C:\PBP\PBPPIC14.LIB 463 : Symbol not previously defined (EEADRH)
    Error[113] C:\PBP\PBPPIC14.LIB 477 : Symbol not previously defined (EEADRH)
    Error[113] C:\PBP\PBPPIC14.LIB 491 : Symbol not previously defined (EEADRH)
    Error[113] C:\PBP\PBPPIC14.LIB 899 : Symbol not previously defined (EEADRH)
    Error[113] C:\PBP\PBPPIC14.LIB 449 : Symbol not previously defined (EEDATH)
    Error[113] C:\PBP\PBPPIC14.LIB 463 : Symbol not previously defined (EEDATH)
    Error[113] C:\PBP\PBPPIC14.LIB 477 : Symbol not previously defined (EEDATH)
    Error[113] C:\PBP\PBPPIC14.LIB 491 : Symbol not previously defined (EEDATH)
    Error[113] C:\PBP\PBPPIC14.LIB 823 : Symbol not previously defined (EEDATH)
    This is my very simple program just to test if READCODE work:
    TRISA = %00100000 ' Set PORTA to all input
    TRISB = %00000000 ' Set PORTA to all input
    Char var WORD
    READCODE $100,Char
    I use a 16f628A PIC for my project.
    But if i try to compile the same prog for a 16f88/16f887(just for example) all work fine and i don't get any errors.
    Have you any ideas about it
    Maybe the READCODE istruction don't work on all PIC models ?
    Thanks in advance,
    Gabriele
    Default Re: READCODE Instruction dont'work
    Not all PIC chips have the ability to read and write to their own Flash memory.
    The 16F628A is one that cannot.
    You can use PEEKCODE/POKECODE or LOOKUP2.
    Or there's EEPROM (READ/WRITE/DATA).
    Sep 2011
    Thank Darrel to confirm me that READCODE don't work with 16f628A like i have supposed.
    So just a curiosity; which is more faster between use poke/peek and lookup2 ?
    PS:
    "I Blink, therefore i am"
    It too cool too true in pic's world! ROTFL
