SPI and 18F4550
Results 1 to 11 of 11
Thread: SPI and 18F4550
    New Jersey
    Default SPI and 18F4550
    I'm a SPI virgin. At the same time, I haven't had the fun experience of working with CAN yet. I have a project that requires both
    http://www.picbasic.co.uk/forum/showthread.php?t=16758
    I've searched the forum for SPI but nothing useful comes up that I can use. Right now I'm taking it slow and I'm not worrying about the CAN portion yet. I only want to understand SPI right now and get the 18F4550 and MCP2515 to talk to each other. Can someone help me get the ball rolling and point me in the right direction. If there are some sample codes that would be great!
    Default Re: SPI and 18F4550
    There's an example on MELABS website showing how to use the MSSP module if that's the idea.
    New Jersey
    I think that's the idea. Thanks for the link. I hope I can get this thing working.....
    Aug 2008
    Portugal
    There is also this article that i made;
    http://www.picbasic.co.uk/forum/cont...P-PBP-MSSP-ASM
    Thanks and Regards;
    Gadelhas
    New Jersey
    Thanks for the info. It helped a little but I'm nowhere closer now than I was on Friday. Not one CAN frame received, nor was one sent. Part of my problem is that I don't completely understand the register settings listed in the datasheet. I keep reading it but it's not 100% clear so I'm sure my settings in the code aren't going to work. Can you (or anyone else) take a look at this and let me know where my mistakes are? I'm sure there are plenty
    DEFINE OSC 20
    '                       REGISTERS AND PINOUT ( 1 = IN; 0 = OUT )
               '76543210          '76543210
     TRISA   = %11011111: PORTA = %00000000
     TRISB   = %00000000: PORTB = %00000001
     TRISC   = %00010000: PORTC = %00000000
     TRISD   = %00000000: PORTD = %00000000
     TRISE   = %00000000: PORTE = %00000000
     ADCON0  = %00000000
     ADCON1  = %00000000
     ADRESH  = %00000000
     ADRESL  = %00000000
     CMCON   = %00000000
     SSPSTAT = %00000000       'I'M A LITTLE LOST WITH THE SSPSTAT AND SSPCON1
     SSPCON1 = %00110000
     '                  VARIABLES AND CONSTANTS
    TXBNCTRL var byte
    TXBNSIDH var byte
    TXBNSIDL VAR BYTE
    TXBNDLC VAR BYTE
    TXBNDM7 VAR BYTE
    TXBNDM6 VAR BYTE
    TXBNDM5 VAR BYTE
    TXBNDM4 VAR BYTE
    TXBNDM3 VAR BYTE
    TXBNDM2 VAR BYTE
    TXBNDM1 VAR BYTE
    TXBNDM0 VAR BYTE
    B0 VAR BYTE
    B1 VAR BYTE
    B2 VAR BYTE
    B3 VAR BYTE
    B4 VAR BYTE
    B5 VAR BYTE
    B6 VAR BYTE
    B7 VAR BYTE
    B7 = TXBNDM7     ' 8TH BYTE OF DATA FRAME
    B6 = TXBNDM6     ' 7TH BYTE OF DATA FRAME
    B5 = TXBNDM5     ' 6TH BYTE OF DATA FRAME
    B4 = TXBNDM4     ' 5TH BYTE OF DATA FRAME
    B3 = TXBNDM3     ' 4TH BYTE OF DATA FRAME
    B2 = TXBNDM2     ' 3RD BYTE OF DATA FRAME
    B1 = TXBNDM1     ' 2ND BYTE OF DATA FRAME
    B0 = TXBNDM0     ' 1ST BYTE OF DATA FRAME
     'THE PIC MUST ENABLE THE CANINTE.TXINE BIT TO CHANGE THE INTERRUPT FLAG
     'THE PIC MUST CLEAR THE TXBNCTRL.TXREQ BIT BEFORE WRITING TO THE TRANSMIT BUFFER
    '                         ALIAS & MODIFIERS
    CS VAR PORTB.4
    SCLK VAR PORTC.3
    SDI VAR PORTB.0
    SDO VAR PORTC.7
    SENDLED VAR PORTA.5             'LED TO INDICATE THE PROGRAM IS IN THE SENDING ROUTINE
    MAINLED VAR PORTE.2             'LED TO INDICATE THE PROGRAM IS IN THE MAIN ROUTINE
    '                           START OF PROGRAM
    START:
    TOGGLE MAINLED              'LED INDICATING THE 18F4550 IS IN THE MAIN ROUTINE
    PAUSE 100
    GOSUB SENDCANDATA           'CAN DATA IS ABOUT TO BE SENT......OR WE COULD ONLY WISH......
    GOTO START
    '                           SEND CAN DATA SECTION
    SENDCANDATA:
    PAUSE 50
    TOGGLE SENDLED              ' LED FOR DEBUGGING
    LOW CS                      ' CS PIN IS HELD LOW IN ORDER TO TRANSMIT DATA
    TXBNDLC = %00000111         ' DATA LENGTH. THIS IS FOR 8 BYTES.
    TXBNCTRL = %00001011        ' THE TXBNCTRL IS A REGISTER THAT DETERMINES THE CONDITIONS UNDER WHICH THE MESSAGE WILL BE TRANSMITTED. SEE DATA SHEET FOR DESCRIPTION.
    TXBNSIDL = %11100000        ' STANDARD IDENTIFIER BITS
    TXBNSIDH = %11111111        ' NOT REALLY SURE WHAT MICROCHIP WANTS HERE. IT JUST STANDARD IDENTIFIER BITS?
    B0 = $0                     'DATA IN BYTE 1
    B1 = $01                    'DATA IN BYTE 2
    B2 = $03                    'DATA IN BYTE 3
    B3 = $06                    'DATA IN BYTE 4
    B4 = $08                    'DATA IN BYTE 5
    B5 = $0A                    'DATA IN BYTE 6
    B6 = $0C                    'DATA IN BYTE 7
    B7 = $0E                    'DATA IN BYTE 8
    IF TXBNCTRL.3=1 OR TXBNCTRL.5=1 OR TXBNCTRL.4=1 THEN GOTO SENDCANDATA   'THERE WAS AN ERROR, TRY AGAIN.
    HIGH CS                     ' DATA TRANSMISSION IS COMPLETE. PUT CS LINE BACK TO 1.
    PAUSE 1000
    As far as I can see there's nothing in your code that actually sends any data anywhere. In the SENDCANDATA you pull the CS line low, then you assign some values to a couple of variables, then you pull CS line high again. There's nothing to actually shift any data out of the PIC using either SHIFTOUT/SHIFTIN or the MSSP module.
    Is there any chance you've looked at some code for a PIC with a built in CAN tranceiver? Is that perhaps where the TXBNDLC etc variables are coming from? If so, then those are probably registers for that particular PICs internal CAN tranceiver and simply creating variables with the same name will obviously not get anything out of your 2550 and into an external CAN tranceiver.
    New Jersey
    I was thinking the same thing last night about sending data but I really don't know how the SPI function works. Here is an excerpt from the MCP2515 data sheet (stand alone CAN IC) where I got the TXBNDLC variable from:
    Yeah, but that register is in the MCP2515 - you're only assigning values to variables in the PIC, there's currently nothing that transfers the data TO the register in the MCP2515.
    Look at the SPI section of the datasheet for the MCP2515, under Write instruction it says
    The Write instruction is started by lowering the CS pin. The Write instruction is then sent to the MCP2515 followed by the address and at least one byte of data.
    Then, looking at table 12-1 we can see that the Write instruction is (in binary) 00000010 or 2 in decimal. As you can see in your screenshot from the datasheet the adress of the TXBnDLC register(s) in the MCP2515 is $35, $45 and $55 respectively (apparently there's three of them, I haven't read enough yet to understand exactly what they do).
    So to set the first of the TXBnDLC registers you need to shift out the WriteCommand (2), the adress ($35) and the actual data (7). The SPI section of the datasheet also tells us the device supports mode 0,0 and 1,1 and the timing diagram shows that it expects (and sends) MSB first. So, using SHIFTOUT the above would look something like
    INCLUDE "modedefs.bas"
    Write_Cmd CON %00000010    ' Value for the Write Command
    TXB1DLC CON $35                  ' Adress of the 1st TXBnDLC register in the MCP2515
    LOW CS
    SHIFTOUT DataPin, ClkPin, MSBFIRST, [Write_Cmd, TXB1DLC, 7]
    HIGH CS
    The example I linked to earlier and the article gadelhas wrote shows you how to set up and use the MSSP module.
    New Jersey
    Henrik,
    You've made it a little clearer for me, thanks. I'm going to work with this today to see if I can get it to work. Something is strange with the demo boards I've received from Microchip. I can't erase the chip and even blinking an LED can be a task. I'm not even sure if the program I'm compiling is even getting to the 18F4550 at certain times. When I make the same circuit on a breadboard it doesn't give me any problems so I may have two issues at the same time, which makes things even more difficult.
    Chris
    New Jersey
    I'm getting closer. I couldn't figure out what was going on so I pulled out my scope and it seems pretty clear......at least for this step. This is a picture of the scope with a known good program (I'm using the same board for the working program and my program so I know the hardware is good). Yellow is the data and blue is the CS line.
    Name:  Known working CAN data.jpg
    Now look at the scope with my program:
    Name:  My code transmitting CAN data.jpg
    So my signal looks like it's inverted. They speak about this in the BAUDCON, TXSTA and RXSTA settings but I tried adjusting them and it didn't help. Any ideas?
    EDIT - It was under the SSPSTAT.6. The signal is correct now but still no CAN data. At least I'm getting closer......
    Ok, what exactly are we looking at?
    My guess is the MOSI pin on the PIC (Ch1) and the CS line (Ch2)?
    Without seeing your code it's a bit hard to guess what you're actually doing but what I can say is that BAUDCON, TXSTA and RXSTA (if we're talking about the PIC) are control registers for the USART and has nothing to do with the either the MSSP module or the SHIFTOUT/SHIFTIN - whatever you're actually using. Post the code ;-)
