Two statements from assembly - trying to convert the code in PBasic Pro
Results 1 to 14 of 14
    Nov 2009
    London
    Default Two statements from assembly - trying to convert the code in PBasic Pro
    Can someone please advise what the following two statements mean (or doing) in the code? I have the code in assembly which I am converting to basic pro, but I don't have a clue what these statements are doing. They are extracted from the ISR routine.
    movlw   ((INTHAND) >> 8)
    movwf   PCLATH
    May 2006
    Del Rio, TX, USA
    Default Re: Two statements from assembly - trying to convert the code in PBasic Pro
    movlw ((INTHAND) >> 8) => Shift the constant (literal) 8 bits right (equivalent to dividing by 256) then put the value in WREG
    movwf PCLATH => Move the value in WREG into PCLATH.
    So, these two statement combined are putting INTHAND/256 into the the middle byte of the program counter.
    Nov 2009
    London
    Steve, but
    1)INTHAND is not a variable, in fact it is mentioned in the statement
    define      INTHAND     _ISR
    2)What is the basic purpose of loading value in PCLATH
    cheers
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by Megahertz View Post
    Steve, but
    define      INTHAND     _ISR
    Yes, you are right. But I didn't say it was a variable.
    The PCLATH is used (along with PCLATU) to make changes to the Program Counter, which is akin to directing the the program to a new location in the code: a "Computed GOTO."
    Nov 2009
    London
    Where is the constant here?
    I really suck at assembly programming but I'm going to say (write) what I think, then hopefully someone will correct me if I'm wrong.
    The constant in this case is called INTHAND which is defined to contain the adress, in program memory, where the routine _ISR is located. What happens is that PCLATH (the high byte of the program counter) gets loaded with the 8 high bits of the adress of _ISR. I suspect there's also code to take the low 8 bits and put them in PCLATU. All in all, that would cause the program to jump to _ISR.
    After reading SteveB's other posts that's my understanding of it but again I might very well be wrong.
