Problems with my "intelligent timer"
Results 1 to 16 of 16
    Dec 2008
    Ploiesti, ROMANIA
    Default Re: Problems with my "intelligent timer"
    I think in this subroutine the "pause xxx" commands make problems... It's another way to do this ?
    wipper:
    while gpio.5 = 0
    LED = 1
    PAUSE 1000
    LED = 0
    PAUSE (wipp_time * 1000)  ; this command run for (wipp_time * 1000) seconds  even gpio.5 is no more = 0 ?!?
    wend
    Dec 2011
    IO93ok
    How about something like a 'for next' loop:-
    For wipp_time = 1 to 10 ;adjust for your required timing delay
    Next wipp_time
    Dec 2008
    Ploiesti, ROMANIA
    Thanks for reply...but wipp_time dont have just 1 to n value ...It's "seconds elapsed between two pushing of button @gpio.5" !
    I dont understand why in "while...wend" command, the failure of condition " gpio.5 = 0" dont stop the "pause (wipp_time * 1000)" command and dont return to master (loop) ...
    May 2008
    Italy
    You have to write:
    Delay VAR word
    Wipper:
    Delay = wipp_time * 1000
    While gpio.5 = 0
    Pause 1000
    Led = !Led
    If Delay= 0 then Skip_0
    Pause 1
    Delay = Delay - 1
    Skip_0:
    Wend
    Cheers
    Al.
    Dec 2008
    Ploiesti, ROMANIA
    Thank You !
    ...but the schematic dont work if I wish ...
    @ Device PIC12F675,INTRC_OSC_NOCLKOUT, WDT_OFF,PWRT_ON,PROTECT_OFF,MCLR_OFF,BOD_OFF
    Include "C:\WIPPER\Elapsed.bas"   ' just wsave(s) removed
    CLEAR
    ANSEL=0
    CMCON=7
    TRISIO=%00100000
    maneta      var gpio.5
    LED         var GPIO.2         ' set GPIO.0 port as OUTPUT (LED)
    wipp_time   var byte           ' number of seconds while LED=off
    nr          var bit
    delay       var word
    nr = 0
    low LED
    Gosub ResetTime                ' reset Time to  0d-00:00:00.00
    IF GPIO.5 = 1 then
      nr=nr+1
         if nr=1 then
            gosub memo             ' set wipe_time
            gosub wipper           ' use seconds elapsed as wipe_time
            nr = 0                 ' ready for another setting of wipe_time
    if nr > 2 then nr =  0
    Goto Main
    memo:
    gosub StartTimer
        while maneta = 1
          	wipp_time = seconds    ' seconds counts from the beginning of gpio.5 = 0
        wend
    Gosub StopTimer
    Gosub ResetTime
    Wipper:
    While gpio.5 = 1
    Pause 1000
    Led = !Led
    Pause 1
    Delay = Delay - 1
    Skip_0:
    Wend
    Dec 2008
    Ploiesti, ROMANIA
    There are other advices ?! Please !
    Dec 2008
    Ploiesti, ROMANIA
    I think it's a problem with the title of my topic ... since me I am not intelligent enough to solve this !
    I try another way :
    CLEAR
    ANSEL=0
    CMCON=7
    TRISIO=%00100000
    maneta      var GPIO.5
    wipp_time   var word           ' number of seconds while LED=off
    nr          var word
    nr = 0
    IF maneta = 1 then
    nr = nr + 1
        if nr= 1 then
           gosub memo
           gosub wipper
    Goto Main
    memo:
        while maneta = 1
        low led
          	wipp_time = wipp_time + 1    ' counting in 100 ms steps
        wend
    nr = 1
    Wipper:
        while maneta = 1
            high led
            low led
            pause wipp_time * 100
        wend
    nr = 0
    wipp_time = 0
    Without results ! Variable "nr" seems to NOT increase ...I push "maneta", then go to memo, I push again, then go to wipper, I push again, then go to wipper again ?!?
