If ... Then Problem
Results 1 to 3 of 3
    Apr 2009
    Unhappy If ... Then Problem
    Hi All,
    I'm using an Ultrasonic Sensor to determine the level of fuel in a storage tank.
    This Sensor puts out a 0 to 5 Volt analog signal depending on the level in the tank.
    This problem appears when the analog voltage is 1 Volt or less.
    I'm using If ... Then's to determine the current fuel level. Every level seems to
    be fine except for Screen21 and Screen19 just above the "End" statement. For
    some unknown reason, Screen21 & Screen19 alternate when this code is running.
    (When the analog voltage is .5 Volt, Screen21 should be called up. When the
    voltage is 1 Volt, Screen19 should be on). I've put the following code line in my
    program in order to troubleshoot this problem without success:
    Debug 12, "Value: ", Bin8 A2D_V 'Display the Binary value
    Any Help at all, will be greatly appreciated!!!
    '* Name : UNTITLED.BAS *
    '* Notice : Copyright (c) 2012 [select VIEW...EDITOR OPTIONS] *
    '* : All Rights Reserved *
    '* Date : 5/2/2012 *
    '* Version : 1.0 *
    '* Notes : *
    CLEAR ;always start with clear
    DEFINE OSC 4 ;define oscillator speed
    DEFINE ADC_BITS 8 ; Sets number of bits in result
    DEFINE ADC_CLOCK 3 ; Sets clock source (3=rc)
    DEFINE ADC_SAMPLEUS 50 ; Sets sampling time in uS
    define DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    define DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0
    DEFINE DEBUG_PACING 1000
    define BUTTON_PAUSE 50
    Low PORTE.2 ;makes low for write only
    TRISA = %00001111 ;sets 0, 1, 2, and 3 as porta inputs (A to D's & ref's)
    TRISB = %00111111 ;sets bits 6 & 7 portb pins as outputs, 0 thru 5 as inputs
    TRISC = %10111111 ;sets port c.6 for serial output
    TRISD = %00000011 ;sets PORTD 0,1, lines to inputs, rest to outputs
    TRISE = %00000000 ;sets all PORTE lines to outputs
    A2D_V var byte ;created to store Tank's Fuel Level
    Start:
    if portc.0 = 0 then start 'If portc.0 = 1, take a measurement
    Pause 2000
    ADCON1=%00000010 'Setup to read analog inputs
    ADCIN 0, A2D_V 'Read channel 0 to A2D_Value
    pause 2000
    If (A2D_V <=%00011001) then Screen21
    ' 0 25
    If (A2D_V >=%00011010)and(A2D_V <=%00110010) then Screen19
    ' 26 50
    If (A2D_V >=%00110011)and(A2D_V <=%01001011) then Screen17
    ' 51 75
    If (A2D_V >=%01001100)and(A2D_V <=%01100100) then Screen15
    ' 76 100
    If (A2D_V >=%01100101)and(A2D_V <=%01111101) then Screen13
    ' 101 125
    If (A2D_V >=%01111110)and(A2D_V <=%10010110) then Screen11
    ' 126 150
    If (A2D_V >=%10010111)and(A2D_V <=%10101111) then Screen9
    ' 151 175
    If (A2D_V >=%10110000)and(A2D_V <=%11001000) then Screen7
    ' 176 200
    If (A2D_V >=%11001001)and(A2D_V <=%11100001) then Screen5
    ' 201 225
    If (A2D_V >=%11100010)and(A2D_V <=%11111010) then Screen3
    ' 226 250
    If (A2D_V >=%11111011) then Screen1
    ' > or = to 251
    Pause 2000
    Goto Start
    Screen1:
    pause 2000
    Debug 12, 27, 69, "1", 32 '100% Fuel Remaining Screen
    Goto Start
    Screen3:
    Pause 2000
    Debug 12, 27, 69, "3", 32 '90% Fuel Remaining Screen
    Goto Start
    Screen5:
    Pause 2000
    Debug 12, 27, 69, "5", 32 '80% Fuel Remaining Screen
    goto Start
    Screen7:
    pause 2000
    Debug 12, 27, 69, "7", 32 '70% Fuel Remaining Screen
    goto Start
    Screen9:
    Pause 2000
    Debug 12, 27, 69, "9", 32 '60% Fuel Remaining Screen
    goto Start
    Screen11:
    Pause 2000
    Debug 12, 27, 69, "11", 32 '50% Fuel Remaining Screen
    goto Start
    Screen13:
    Pause 2000
    Debug 12, 27, 69, "13", 32 '40% Fuel Remaining Screen
    goto Start
    Screen15:
    Pause 2000
    Debug 12, 27, 69, "15", 32 '30% Fuel Remaining Screen
    goto Start
    Screen17:
    pause 2000
    Debug 12, 27, 69, "17", 32 '20% Fuel Remaining Screen
    goto Start
    Screen19:
    Pause 2000
    Debug 12, 27, 69, "19", 32 '10% Fuel Remaining Screen
    Pause 2000
    Screen21:
    Pause 2000
    Debug 12, 27, 69, "21", 32 'Out of Fuel Screen
    Pause 2000
    goto Start
    Default Re: If ... Then Problem
    A missing Goto Start at the end of the Screen19 routine perhaps?
    Apr 2009
    I must be tired to have missed something this obvious!
    The problem has been solved.
    Thank You Henrik!
