Do not take this wrong, but it seems you need to learn a little more about your hardware before you go advanced.
Take a look at the PIC's data sheet under electrical and you will find the voltage vs speed.
Hmmmn.
I can take a look at the data sheet but not really understand it. What exactly am I looking at? I have always found I can understand about 0.2% of the data sheet.
The 18F24K22 has an operating voltage of 1.8 to 3.6 volts as is. When you open the data sheet this information is on page #1 (pdf page #3)
Then look at section 26.
So run the 18F24K22 at the rated voltage and you should be fine.
