Lcd On Porta And Portb
Results 1 to 6 of 6
    EDWARD's Avatar
    EDWARD Guest
    Default Lcd On Porta And Portb
    I am ICSP programming a board with a 16f73 and 14 pin lcd among other devices. For some weird reason the developer of the board,whom i do not know, has put D7, D6, D5, D4 of the LCD to PINS PORTA.0, PORTA.1, PORTA.2, PORTB.3 on the 16f73 repectivley. yes i said PORTB.3 not PORTA.3. Its seems that the pins for the LCD are connected in reverse and not all on the same port.
    the last bit of information you should know is that there is a 256 eeprom chip connected serially to PORTB.1 AND PORTB.2.
    thus far LCDOUT has been unsucessful
    i have read tons of forums before posting
    CAN ANY OF you invision a work around?
    things to consider.
    i would like to use the LCDOUT command.
    will using the eeprom to drive the LCD be an option? i.e load bytes from eeprom to the ports registers.
    can i somehow make portB.3 do exactly what portA.3 does?
    '----------------------------------------the hardware\defs i have
    E is portC.1
    rs is portC.0
    R/W is grounded (write mode)
    Data0 to Data3 is not used
    I am in HS mode
    14 pin 2x8 lcd
    define LCD_DREG PORTA
    define LCD_DBIT 0
    define LCD_RSREG PORTC
    define LCD_RSBIT 0
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 1
    define LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    'holla
    Feb 2004
    Germany
    EDWARD,
    there is no need to post the very same question in two different categories.
    see here
    and please have a look at this
    regards
    Ralph
    G8RPI's Avatar
    G8RPI Guest
    Hi Edward,
    all the data bits must be on one port to use LCDOUT command.
    Robert G8RPI.
    EDWARD's Avatar
    EDWARD Guest
    Default Yo Navms
    I DIDNT realize i was in the pbc forum and not the pbp forum dude.
    g8rpi, i knew that was the case, as much i hoped it wasnt. thxs for the help though. how does the LCDOUT work, i mean is it just sending serial data to each of the 4 data lines used on the lcd + the control bits? is it ASCII code? i was hoping i could call a byte of data from the eeprom , sort of like a sequencer that can have defined ports. i need porta.0 porta.1 porta.2 portB.3 to be the 4 data lines to the lcd.
    basically can i use 4 byte long variables to drive the data lines on the lcd?
    thanks for your time
    Feb 2004
    Germany
    Quote Originally Posted by EDWARD
    Then you should have deleted your post in the PBC section before posting here.
    Now you are getting responses to the same question in two different categories and it is hard for all members to keep track of the discussion.
    ..LCDOUT
    The fastest way would be to cross the wires of B3 and A3 and use the built in Routines.
    regards
    Ralph
    EDWARD's Avatar
    EDWARD Guest
    Default okaly dokaly
    *DONT REPLY
    people do due the mass confusion u all seem to be having DO NOT REPLY TO THIS FORM. please go to the pic basic compiler (non-pro edition) forum if you can help
    sry i wanted this to be in the picBasic PRo section, thats what i have, not the other one but too many people started adding to it so as John lennon said Let It Be.
    *DONT REPLY
    *DONT REPLY
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 21:30
  2. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  3. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  4. LCD Data on portA and portB
    By EDWARD in forum mel PIC BASIC
    Last Post: - 22nd July 2005, 15:27
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
