LCD Data on portA and portB
Results 1 to 32 of 32
    Feb 2004
    Germany
    @Dwayne
    how about this:
    This is a qoute
    ' This is no working code!
      Line 1   'not working
      Line 2   'not working
    'etc . . .
    regards
    Ralph
    hansknec's Avatar
    hansknec Guest
    Dwayne,
    You reminded me of another possibility. I too have built my own LCD backpack in the past... just to see if I could do it. Commands were identical to LCDout except I would serout instead. Doesn't add too much to the cost of an assembly and is certainly cheaper than buying a serial LCD. Still its the thought thats nagging me that we should be able to cross the port boundary with the data pins on LCDout. Guess it needs to go in the wish-list column.
    -John
    EDWARD's Avatar
    EDWARD Guest
    Default yo
    that webpage is good but it isnt mine.
    -not sure what exactly your problem is but are you just asking how to get a changing variable on the LCD?
    the subs i made probly wont be that good for that but can be done. youd need to make a routine to turn a byte (or word) sized variables decimal value into ascii format. your gonna need to generate 3 ascii character from a byte sized var.
    example: we have b1 a byte siezed variable.if we need b1 on the lcd we know that the variable is 0-255. that means we need 3 characters reserved for this variable XXX. if b1 =1 then show "001" on lcd. if b1=35 then show "035". if b1=244 then shoe "244".
    i may end up doing something like this if it doesnt require a lot of room and ill post it if i do it.
    Dec 2003
    Wichita KS
    Hello Hancksnec,
    Which will probably mean more overhead and less space for your code. Everything has a drawback... Maybe they could call it LCDoutX ? For those who do not want to have the extra overhead.
    How do you like your C compiler?
    Dwayne
    Ability to Fly:
    Pilots that are Flying:
    Dec 2003
    Wichita KS
    Hello Ralph,
    @Dwayne
    how about this:
    LCDout Portb,2400T,"Old habits are TOUGH to break ;-}"
    Thanks bud!
    Dwayne
    Ability to Fly:
    Feb 2004
    Germany
    Quote Originally Posted by Dwayne
    Thanks bud!
    You are welcome!
    regards
    Ralph
    hansknec's Avatar
    hansknec Guest
    Do I like my C compiler? Well it has its advantages in many situations, but I still love PBP.
    Try doing this in basic:
    ////                 Polarization analysis.C                         ////
    ////  This program shows input, output and standard operations with  ////
    ////  floating piont numbers.  I/O is RS232.                         ////
    ////  The equation is applied to the numbers entered and the result  ////
    ////  is printed to the screen.               hansknecht 5/12/04     ////
    #include <16F877.h>
    #fuses HS,NOWDT,NOPROTECT,NOLVP
    #use delay(clock=20000000)
    #use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
    #include <stdlib.h>
    #include <input.c>
    #include <math.h>
    void main()
     float a, b, pol_res;
     do {
            printf("\r\nEnter first number: ");  //prompt user for number
            a=get_float();                       // bring number in
            printf("\r\nEnter second number: ");  // prompt for second number
            b=get_float();
            pol_res = (2*(SQRT (a*b))/(a+b))* 100;  // perform calculation
            printf("\r\nPolarization = ",pol_res, " %"); // display result
        } while (TRUE);
    I also like the wizard associated with the CCS C compiler. When you start a new project it asks you questions like "Do you want to use the on-board ADC?" or "Do you want to use the Capture-Compare?". Based on your answer it automatically inserts the necessary code for initialization.
    All this comes at a $$$ price. PBP is a great affordable compiler for 90% of my projects.
    -John
  1. Matrix Keypad routine
    By mister_e in forum Code Examples
    Last Post: - 18th September 2022, 20:30
  2. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 19:52
  3. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 20:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 5th May 2005, 23:29
