Current to Voltage Converter Schematic Question
Results 1 to 11 of 11
    Aug 2012
    Default Re: Current to Voltage Converter Schematic Question
    It started with 4-20mA so a normal resistor will not provide 0-5V rather it would give 1-5V. This will decrease the accuracy to 20%.
    it seems to me, it is a standard current signal of 4-20mA.
    For this reason, you need to use op-amp. Have a look at the circuit.
    Dec 2010
    Quote Originally Posted by tufail74 View Post
    Actually, it decreases the dynamic range, and is easily compensated for without op-amps.
