MMC and PIC
Results 1 to 9 of 9
Thread: MMC and PIC
    kasapo's Avatar
    kasapo Guest
    Red face MMC and PIC
    while interfacing a mmc card and PIC 16f877, do i have to use RC3 RC4 and RC5 pins of PIC for DATAIN, DATAOUT and CLOCK inputs of MMC card ?
    can i use pins of PORTE ?
    Sep 2003
    Vermont
    If you are going to use PBP, you can use any port pin as long as it does not interfere with the operation of other peripherals you need, or you try to make an input only pin an output. If you are going to use the internal hardware MSSP port, you must use the pins described specifically for that operation. I have used both, and the hardware port will give you much greater speed, but less flexibility. Writing 500 plus bytes per shot can create a bottleneck in information flow. If you are acquiring data at a slow rate, I suggest shiftin and shiftout. If you feel a need for speed...Go hardware.
    Ron
    Australia
    Hi Ron & kasapo,
    I am interested in MMC card too. Could you please present a piece of code how PIC reads and writes from/to MMC card? I am using EEPROM which seems not good enough (two small). My project needs to store more than 10MBytes log information using PIC.
    Thank you.
    Yuantu Huang
    kasapo's Avatar
    kasapo Guest
    Smile sa25f160
    hi Yuantu,
    if 10 mB is enough for you check sa25f160 serial flash from saifun semiconductor. it is 16 mB.
    and i found 2 website about mmc and pic basic codes
    http://www.compsys1.com/workbench/
    http://www.captain.at/electronics/pic-mmc/
    ron thanks for information.
    Sep 2003
    Vermont
    I have used Compsys1 for the software. It is reasonable, and it formats the card as a fat 16 readable "disk" for the average computer. This means you don't have to feed the info into a serial port, just plug the mem card into the card reader port and open it like any other folder.It saves a lot of time, and if this will be a consumer product, makes it more convenient for them.
    Ron
    Australia
    Hi Ron & kasapo,
    Thank you very much.
    I will visit the web site you provided. Our products may have 5000-10000 units per year. So I need to take some time to make a decision whether we use sa25f160 or Compsys1.
    Best regards,
    Yuantu Huang
    Jun 2008
    Varese , Italy
    Default mmc picbasic pro
    Quote Originally Posted by Yuantu Huang View Post
    Hi Ron & kasapo,
    Thank you.
    Good day,
    I am intereste in a program capable of writing_reading data on mmc card using picbasic: any help ? any sample code ?
    Ambrogio
    Dec 2006
    WADSWORTH OHIO USA
    Wink mmc or usb?
    I have a good idea from mmc to pic but my cohorts still want to go from pic to usb...
    We are using 16f devices, I wanted to go I2C to mmc... OK and
    THEY now want to go USB....
    From everything I have read 18f is the way to go for usb,
    I don't want to change the entire system just to record data...
    would love to here other ideas....
    Thanks !
    SOMRU
    TWE/TFP/EE
  1. SD or MMC card as storage for logging
    By HYETİK in forum mel PIC BASIC Pro
    Last Post: - 16th January 2012, 03:07
  2. picbasic pro SD_MMC
    Last Post: - 24th September 2009, 12:17
  3. Picbasic MMC SD : sdfs3.bas
    Last Post: - 27th April 2009, 16:03
  4. Where should I discuss SD/MMC FAT issues?
    By JD123 in forum General
    Last Post: - 2nd April 2008, 22:41
