Hello Scampy,
Thank you very much in advance for participating and answer,
As we see the result of your Google searching is as same as my text, isn't it?
Quote Originally Posted by Scampy View Post
from a quick google I found these settings for use with a 20mhz crystal from the datasheet with a 48mhz USB timing
 __CONFIG    _CONFIG1L, _PLLDIV_5_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
 __CONFIG    _CONFIG1H, _FOSC_HS_1H
If our suggestions be right, perhaps the wrong point would be on some where else.
I still need HELP!
Andy
