how to store received values in serial communication ?
Results 1 to 7 of 7
    Jun 2012
    Default how to store received values in serial communication ?
    hi all
    i recieve values in the following form from a device
    =123456
    i want to store the 3 decimal values after the "=" character
    i can't figure out a way to do this
    i used this line but it only stores one values and i don't know if it store it as decimal or not, what should the # do to the values ?
    the line i used
    SERIN RX,T2400,["="],SER1
    when i tried to store two values it didn't give me anything !
    SERIN RX,T2400,["="],SER1,SER2
    can u help me plz
    urgent !
    Default Re: how to store received values in serial communication ?
    Jun 2012
    could u give me a line that i can use instead of a 30 line that i should read !
    Jun 2012
    IT SHOWS ME THESE ERRORS WHEN trying to use it
    Serin2 RX,396,[WAIT("="),DEC A0]
    Serout2 TX,396,["3: ",DEC A0,13,10]
    \NEW FOLDER (2)\WEIGHT.PBP ERROR Line 87: Bad expression.
    \NEW FOLDER (2)\WEIGHT.PBP ERROR Line 88: Bad expression.
    Maybe you could post your code and tell us what chip you are using...
    Jun 2012
    '* Name : 7SEG-MULTIPLEXING.BAS *
    '* Author : [ Eng. Mohammad Aqel ] *
    '* Date : 11/9/2007 *
    DEFINE OSC 20
    ' Set LCD Data port
    DEFINE LCD_DREG PORTD
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTD
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 0
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTD
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 1
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    ' Set data delay time in us
    DEFINE LCD_DATAUS 50
    INCLUDE "modedefs.bas"
    ' Set baud rate
    DEFINE HSER_SPBRG 129 ' 2400 Baud @ 0.17%
    datain var byte
    SerialData var byte
    COUNTER VAR WORD
    COUNTER1 VAR BYTE
    COUNTER2 VAR BYTE
    ASCII VAR BYTE
    Ser var byte[40]
    Ser1 var byte
    A var byte[5]
    B var byte[5]
    i var byte
    j var byte
    ADCON1 = 6 'PORTA AND e DIGITAL
    TRISC = %10000000 ' PORTC.7 is the RX input
    ' PORTC.6 is the TX output
    TRISB=0
    TRISD=0
    TRISA=0
    PORTD=$FF
    PORTB=0
    A0 var WORD
    A1 var WORD
    A2 var WORD
    A3 var byte
    A4 var byte
    A5 var byte
    A6 var byte
    DEFINE SER2_BITS 4 ' Set Serin2 and Serout2 data bits to 4
    DEFINE SER2_BITS 5 ' Set Serin2 and Serout2 data bits to 5
    DEFINE SER2_BITS 6 ' Set Serin2 and Serout2 data bits to 6
    DEFINE SER2_BITS 7 ' Set Serin2 and Serout2 data bits to 7
    DEFINE SER2_BITS 8 ' Set Serin2 and Serout2 data bits to 8 (default)
    b0 var byte
    num var byte
    Hex_input var byte
    A_D_A VAR WORD [9]
    MAIN:
    'hserin [WAIT( "=" ) ,dec3 a0]
    'Serin2 RX,396,[WAIT("="),dec a0]
    Serin2 RX,396,[WAIT("Y-"),DEC A0]
    A3=Ser dig 3
    A4=a0 dig 0
    A5=a0 dig 1
    A6=a0 dig 2
    LCDOUT $fe,$80, dec2 A0
    LCDOUT $fe,$c0, dec A4, dec A5, dec A6
    goto MAIN
    eND
    i used pic16f877
    Add to the Variable section of your code to let the compiler know the pins you are using
    RX VAR PORTC.7
    TX VAR PORTC.6
    Or
    Serout2 POTRC.6,396,["3: ",DEC A0,13,10]
    And the same for SERIN2.
    Either way, you need to tell the compiler.
    Why are you adding
