Dallas CRC8 Routines
Results 1 to 24 of 24
    Tom,
    I finally have everything working properly. Thank you so very much for your help and understanding.
    taats's Avatar
    taats Guest
    Default Crc8
    after a couple of hours of hard work, i got it working now...
    so thanks anyway!!,
    Taats
    Is there an easier way to do this?
    owin portb.7,0,[data_in[0], data_in[1], data_in[2], data_in[3], data_in[4], data_in[5], data_in[6], data_in[7], data_in[8]]
    Jan 2004
    Grand Lake O' Cherokees USA
    Using other 1wire devices I have been able to do the following:
    ' Read the next 32 bytes, calculate running CRC but discard the bytes
    For Index = 1 to 32
    OWIn OWPort, 0, [CRCData]
    GoSub CRC
    Next Index
    OWIn OWPort,0,[DesiredData]
    CRCData = DesiredData
    GoSub CRC
    In other words there may be enough time in between data bytes sent from the 1 wire device to calculate the CRC on a running basis. If you don't need all the data the CRC can be calculated and the data discarded, retaining only that data you need.
    Tom
    I was wondering if that would actually work or not. This is my final line. Again thanks for all your help.
        for x = 0 to 8
        owin portb.7,0,[i]
        dq[x] = i
        next x
  1. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 22:01
  2. dallas ibutton to pics
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 12:55
  3. Dallas 1-wire search Routine
    By jimbab in forum Code Examples
    Last Post: - 7th April 2006, 16:14
  4. Dallas Semiconductor Components Serial Numbers
    By ideaman234 in forum General
    Last Post: - 27th February 2006, 22:17
  5. Dallas CRC16 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 16th May 2005, 15:29
