Dallas CRC8 Routines
Results 1 to 24 of 24
    Aug 2005
    Michigan, USA
    Default Re: Dallas CRC8 Routines
    If your concern is size and speed, why not use it as is with he addition of _ before CRC variable (_CRC)?
    I think it will work just fine.
    Hi Ioannis:
    Since the Dattalo method wasn't mentioned in the thread, I simply wanted to pass it along, hoping it might be useful or helpful to PBP users. I'm afraid I don't know how you would implement it in PBP.
    While I've tried all of the methods discussed in this thread in the past, now days in my C programs I use bit level cumulative CRC built into my low level 1-Wire read/write bit driver. Total cost for doing it this way is 8 words of program memory, 1 byte of RAM, and 0 cycles processing overhead since the CRC code executes during a portion of the delay required to fill out the 60 usec read slot timing.
    Cheerful regards, Mike
    Hmm, yes I see what you mean. In Basic this does not seem an easy job to do.
    I will try it and see if it works.
    My main concern is how to save the W register and then restore it.
    I tried
    MOVW _wsave
    but did not compile.
    May 2006
    Del Rio, TX, USA
    I tried
    MOVW _wsave
    The command would be: movwf
    Here is a quick attempt at converting the asm to PBP. Note that this is not the most efficeint/elegant conversion, but it should be a bit clearer was to what's happening.
    crc VAR BYTE
    i_w VAR BYTE
    goto start
    crc_8:
       crc = i_w ^ crc        ;xorwf crc,f
       i_w = 0                   ;clrw
       IF crc.0 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $5E    ;xorlw 0x5e
          END IF
       IF crc.1 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $BC    ;xorlw 0xbc
          END IF
       IF crc.2 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $61    ;xorlw 0x61
          END IF
       IF crc.3 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $C2    ;xorlw 0xc2
          END IF
       IF crc.4 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $9D    ;xorlw 0x9d
          END IF
       IF crc.5 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $23    ;xorlw 0x23
          END IF
       IF crc.6 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $46    ;xorlw 0x46
          END IF
       IF crc.7 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $8C    ;xorlw 0x8c
          END IF
       crc = i_w             ;movwf crc
    start:
     crc = 0                    ;clrf crc
     i_w = 1                    ;movlw 1
     GOSUB crc_8            ;call  crc_8
     crc = 0                    ;clrf crc
     i_w = 2                    ;movlw 2
     crc = 0                    ;clrf crc
     i_w = 4                    ;movlw 4
     crc = 0                   ;clrf crc
     i_w = 8                   ;movlw 8
     crc = 0                   ;clrf crc
     i_w = $10                ;movlw 0x10
     crc = 0                   ;clrf crc
     i_w = $20                ;movlw 0x20
     crc = 0                   ;clrf crc
     i_w = $40                ;movlw 0x40
     crc = 0                   ;clrf crc
     i_w = $80                ;movlw 0x80
    USA - Arizona
    This is a translation for another basic compiler:
    Function crc_dattalo(crc As Byte, crc_data As Byte) As Byte
    'dattalo's CRC-8 Function
    '(328_Tcy / 41.0_us)
        Dim i As Byte
        i = crc_data Xor crc
        i = i And 0xff
        crc = 0
        If i.0 = 1 Then
            crc = crc Xor 0x5e
        Endif
        If i.1 = 1 Then
            crc = crc Xor 0xbc
        Endif
        If i.2 = 1 Then
            crc = crc Xor 0x61
        Endif
        If i.3 = 1 Then
            crc = crc Xor 0xc2
        Endif
        If i.4 = 1 Then
            crc = crc Xor 0x9d
        Endif
        If i.5 = 1 Then
            crc = crc Xor 0x23
        Endif
        If i.6 = 1 Then
            crc = crc Xor 0x46
        Endif
        If i.7 = 1 Then
            crc = crc Xor 0x8c
        Endif
        crc_dattalo = crc
    End Function
    Some additional info and comparison between three different approaches: http://www.ccsinfo.com/forum/viewtop...015&highlight=
    Aug 2005
    Michigan, USA
    Even though I'm not a PBP developer, I've always enjoyed exchanging ideas and experiences with members here. That said, I wonder if anyone is interested in my zero overhead CRC8 method, even if it isn't a PBP example?
    In my zero overhead CRC8 method I use a portion of the 60-usec read/write 'slot' time to implement CRC8 at the bit level within the OneWire read bit routine. Here's the tail end of a read bit routine from code for an enhanced mid-range 16F device;
    ;  bit level cumulative CRC (data bit in Carry at entry & exit)
            clrf   WREG             ;                                 |00
            rlf    WREG,W           ; save C in wreg (0x00 or 0x01)   |00
            xorwf  crc,F            ; xor b0 bits, result in 'crc'    |00
            rrf    crc,F            ; is xor result 0 (Carry = 0)?    |00
            skpnc                   ; yes, skip, else                 |00
            iorlw  0x18             ; w = x8+x5+x4+1 poly and bit 0   |00
            rrf    WREG,W           ; restore C, wreg = 0x8C or 0x00  |00
            xorwf  crc,F            ; apply the polynomial or not     |00
    ;  remainder of 60-usec read/write 'slot'
            DelayCy(46*usecs-14)    ; 46-usecs minus 14 cycles        |00
            banksel owtris          ; bank 1                          |01
            bsf     owtris,owpin    ; output hi-z '1' @ 61-usecs      |01
            banksel 0               ; bank 0                          |00
            bsf     INTCON,GIE      ; interrupts on                   |00
            return                  ; Carry = data bit                |00
    Using CRC in my DS18x20 programs is simply a matter of clearing the 'crc' variable before reading the 9 byte DS18x20 'scratchpad' or an 8 byte ROMID and verifying that the 'crc' variable equals zero afterwards. You must read all 9 'scratchpad' bytes to have a valid 'crc'. Just ignore or throw away the bytes you don't need.
    I admit I have no idea if this method could be implemented in PBP with its intrinsic OneWire commands but I suspect you gurus will find a way to use it if you think the method is worthwhile.
    Have fun. Cheerful regards, Mike (K8LH)
  1. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 23:01
  2. dallas ibutton to pics
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 13:55
  3. Dallas 1-wire search Routine
    By jimbab in forum Code Examples
    Last Post: - 7th April 2006, 17:14
  4. Dallas Semiconductor Components Serial Numbers
    By ideaman234 in forum General
    Last Post: - 27th February 2006, 23:17
  5. Dallas CRC16 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 16th May 2005, 16:29
