Dallas CRC8 Routines
Results 1 to 24 of 24
    Aug 2005
    Michigan, USA
    Default Re: Dallas CRC8 Routines
    Has anyone ever converted Scott Dattalo's method (1-Wire Polynomial) to PBP?
    ;  Scott Dattalo's version (20 words, 23 cycles per byte)
    crc_8
            xorwf   CRC,F           ;
            clrw                    ;
            btfsc   CRC,0           ;
            xorlw   0x5E            ;
            btfsc   CRC,1           ;
            xorlw   0xBC            ;
            btfsc   CRC,2           ;
            xorlw   0x61            ;
            btfsc   CRC,3           ;
            xorlw   0xC2            ;
            btfsc   CRC,4           ;
            xorlw   0x9D            ;
            btfsc   CRC,5           ;
            xorlw   0x23            ;
            btfsc   CRC,6           ;
            xorlw   0x46            ;
            btfsc   CRC,7           ;
            xorlw   0x8C            ;
            movwf   CRC             ;
            return                  ;
    It seems like a pretty good compromise between size and performance.
    Regards, Mike
    If your concern is size and speed, why not use it as is with he addition of _ before CRC variable (_CRC)?
    I think it will work just fine.
    Aug 2005
    Michigan, USA
    Hi Ioannis:
    Since the Dattalo method wasn't mentioned in the thread, I simply wanted to pass it along, hoping it might be useful or helpful to PBP users. I'm afraid I don't know how you would implement it in PBP.
    While I've tried all of the methods discussed in this thread in the past, now days in my C programs I use bit level cumulative CRC built into my low level 1-Wire read/write bit driver. Total cost for doing it this way is 8 words of program memory, 1 byte of RAM, and 0 cycles processing overhead since the CRC code executes during a portion of the delay required to fill out the 60 usec read slot timing.
    Cheerful regards, Mike
    Hmm, yes I see what you mean. In Basic this does not seem an easy job to do.
    I will try it and see if it works.
    My main concern is how to save the W register and then restore it.
    I tried
    MOVW _wsave
    but did not compile.
    May 2006
    Del Rio, TX, USA
    I tried
    MOVW _wsave
    The command would be: movwf
    Here is a quick attempt at converting the asm to PBP. Note that this is not the most efficeint/elegant conversion, but it should be a bit clearer was to what's happening.
    crc VAR BYTE
    i_w VAR BYTE
    goto start
    crc_8:
       crc = i_w ^ crc        ;xorwf crc,f
       i_w = 0                   ;clrw
       IF crc.0 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $5E    ;xorlw 0x5e
          END IF
       IF crc.1 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $BC    ;xorlw 0xbc
          END IF
       IF crc.2 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $61    ;xorlw 0x61
          END IF
       IF crc.3 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $C2    ;xorlw 0xc2
          END IF
       IF crc.4 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $9D    ;xorlw 0x9d
          END IF
       IF crc.5 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $23    ;xorlw 0x23
          END IF
       IF crc.6 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $46    ;xorlw 0x46
          END IF
       IF crc.7 = 1 THEN     ;btfsc crc,0
          i_w = i_w ^ $8C    ;xorlw 0x8c
          END IF
       crc = i_w             ;movwf crc
    start:
     crc = 0                    ;clrf crc
     i_w = 1                    ;movlw 1
     GOSUB crc_8            ;call  crc_8
     crc = 0                    ;clrf crc
     i_w = 2                    ;movlw 2
     crc = 0                    ;clrf crc
     i_w = 4                    ;movlw 4
     crc = 0                   ;clrf crc
     i_w = 8                   ;movlw 8
     crc = 0                   ;clrf crc
     i_w = $10                ;movlw 0x10
     crc = 0                   ;clrf crc
     i_w = $20                ;movlw 0x20
     crc = 0                   ;clrf crc
     i_w = $40                ;movlw 0x40
     crc = 0                   ;clrf crc
     i_w = $80                ;movlw 0x80
    USA - Arizona
    This is a translation for another basic compiler:
    Function crc_dattalo(crc As Byte, crc_data As Byte) As Byte
    'dattalo's CRC-8 Function
    '(328_Tcy / 41.0_us)
        Dim i As Byte
        i = crc_data Xor crc
        i = i And 0xff
        crc = 0
        If i.0 = 1 Then
            crc = crc Xor 0x5e
        Endif
        If i.1 = 1 Then
            crc = crc Xor 0xbc
        Endif
        If i.2 = 1 Then
            crc = crc Xor 0x61
        Endif
        If i.3 = 1 Then
            crc = crc Xor 0xc2
        Endif
        If i.4 = 1 Then
            crc = crc Xor 0x9d
        Endif
        If i.5 = 1 Then
            crc = crc Xor 0x23
        Endif
        If i.6 = 1 Then
            crc = crc Xor 0x46
        Endif
        If i.7 = 1 Then
            crc = crc Xor 0x8c
        Endif
        crc_dattalo = crc
    End Function
    Some additional info and comparison between three different approaches: http://www.ccsinfo.com/forum/viewtop...015&highlight=
  1. Problems with CRC8 Calc in 1Wire
    By JohnB in forum mel PIC BASIC Pro
    Last Post: - 16th March 2007, 22:01
  2. dallas ibutton to pics
    By CBUK in forum mel PIC BASIC Pro
    Last Post: - 25th October 2006, 12:55
  3. Dallas 1-wire search Routine
    By jimbab in forum Code Examples
    Last Post: - 7th April 2006, 16:14
  4. Dallas Semiconductor Components Serial Numbers
    By ideaman234 in forum General
    Last Post: - 27th February 2006, 22:17
  5. Dallas CRC16 Routines
    By Tom Estes in forum Code Examples
    Last Post: - 16th May 2005, 15:29
