porta=0 : portb=0 : portc=0 : portd=0
trisa=0 : trisb=0 : trisc=0 : trisd=0
porte=0 : trise=0
harf_reg var byte
adres_sec var byte
yinele var byte
sutun_reg var byte[300]
veri var byte
yazi_reg var byte
i VAR BYTE
x var byte
z var byte
y var byte
t var byte
q var byte
Scroll_Position var byte
temp_byte var byte
temp_bit var bit
sure var byte
yedek var byte
CLEAR : portd=255:sure=500 :GOTO oku:
oku:
call yazi : yazi_reg=yazi_reg+1 : z=harf_reg
for i=1 to z
call yazi : yazi_reg=yazi_reg+1 : call data_sec
for y=0 to yinele
call datalar
sutun_reg[t]=veri : t=t+1
adres_sec=adres_sec+1
next y
next i
t=0
goto gonder
gonder:
Scroll_Position = Scroll_Position + 1
IF Scroll_Position = 16 THEN ; when this is TRUE it clears the matrix(turned off leds) for 1second
Scroll_Position = 0
FOR Q=0 TO 5
for i=0 to 15
portb=sutun_reg[t] : t=t+1
porta=i
portc=%11111110:pauseus sure:portc=%11111111
next i
for i=0 to 15
porta=i
portc=%11111101:pauseus sure:portc=%11111111
next i
for i=0 to 15
porta=i
portc=%11111011:pauseus sure:portc=%11111111
next i
for i=0 to 15
porta=i
portc=%11110111:pauseus sure:portc=%11111111
next i
for i=0 to 11
porta=i
portc=%11101111:pauseus sure:portc=%11111111
next i
t=0
NEXT Q
goto kaydir
kaydir:
yedek=sutun_reg[0]
for i=0 to 30
temp_byte = sutun_reg[i]
temp_Byte = temp_Byte << 1
temp_Byte.0 = STATUS.0
sutun_reg[i] = temp_byte
next i
goto gonder
yazi:
lookup yazi_reg,[12,"HELLO WORLD"],harf_reg
data_sec:
select case harf_reg
case "A"
adres_sec=0 : yinele=5 : return
case "B"
adres_sec=6 : yinele=5 : return
case "C"
adres_sec=12 : yinele=5 : return
case "D"
adres_sec=18 : yinele=5 : return
case "E"
adres_sec=24 : yinele=5 : return
case "F"
adres_sec=30 : yinele=5 : return
case "G"
adres_sec=36 : yinele=5 : return
case "H"
adres_sec=42 : yinele=5 : return
case "I"
adres_sec=48 : yinele=3 : return
case "i"
adres_sec=52 : yinele=3 : return
case "J"
adres_sec=56 : yinele=5 : return
case "K"
adres_sec=62 : yinele=5 : return
case "L"
adres_sec=68 : yinele=5 : return
case "M"
adres_sec=74 : yinele=5 : return
case "N"
adres_sec=80 : yinele=5 : return
case "O"
adres_sec=86 : yinele=5 : return
case "P"
adres_sec=92 : yinele=5 : return
case "Q"
adres_sec=98 : yinele=5 : return
case "R"
adres_sec=104 : yinele=5 : return
case "S"
adres_sec=110 : yinele=5 : return
case "T"
adres_sec=116 : yinele=5 : return
case "U"
adres_sec=122 : yinele=5 : return
case "ü"
adres_sec=128 : yinele=5 : return
case "V"
adres_sec=134 : yinele=5 : return
case "W"
adres_sec=140 : yinele=5 : return
case "X"
adres_sec=146 : yinele=5 : return
case "Y"
adres_sec=152 : yinele=5 : return
case "Z"
adres_sec=158 : yinele=5 : return
case " "
adres_sec=164 : yinele=5 : return
case "0"
adres_sec=170 : yinele=5 : return
case "1"
adres_sec=176 : yinele=3 : return
case "2"
adres_sec=180 : yinele=5 : return
case "3"
adres_sec=186 : yinele=5 : return
case "4"
adres_sec=192 : yinele=5 : return
case "5"
adres_sec=198 : yinele=5 : return
case "6"
adres_sec=204 : yinele=5 : return
case "7"
adres_sec=210 : yinele=5 : return
case "8"
adres_sec=216 : yinele=5 : return
case "9"
adres_sec=222 : yinele=5 : return
end select
datalar:
lookup adres_sec,[$05, $24, $74, $54, $7C, $78_ ;A
,$7F,$49,$49,$49,$36,0_ ;B
,$3E,$41,$41,$41,$22,0_ ;C
,$7F,$41,$41,$41,$3E,0_ ;D
,$7F,$49,$49,$49,$41,0_ ;E
,$7F,$09,$09,$09,$01,0_ ;F
,$3E,$41,$49,$49,$3A,0_ ;G
,$7F,$08,$08,$08,$7F,0_ ;H
,$41,$7F,$41,0_ ;I
,$44,$7D,$44,0_ ;Ý
,$20,$40,$41,$3F,$01,0_ ;J
,$7F,$08,$14,$22,$41,0_ ;K
,$7F,$40,$40,$40,$40,0_ ;L
,$7F,$02,$04,$02,$7F,0_ ;M
,$7F,$04,$08,$10,$7F,0_ ;N
,$3E,$41,$41,$41,$3E,0_ ;O
,$7F,$09,$09,$09,$06,0_ ;P
,$3E,$41,$51,$61,$3E,0_ ;Q
,$7F,$09,$19,$29,$46,0_ ;R
,$26,$49,$49,$49,$32,0_ ;S
,$01,$01,$7F,$01,$01,0_ ;T
,$3F,$40,$40,$40,$3F,0_ ;U
,$1E,$41,$01,$41,$1E,0_ ;Ü
,$1F,$20,$40,$20,$1F,0_ ;V
,$3F,$40,$30,$40,$3F,0_ ;W
,$63,$14,$08,$14,$63,0_ ;X
,$07,$08,$70,$08,$07,0_ ;Y
,$61,$51,$49,$45,$43,0_ ;Z
,$00,$00,$00,$00,$00,0_ ;Space
,$3E,$51,$49,$45,$3E,0_ ;0
,$42,$7F,$40,0_ ;1
,$62,$51,$49,$45,$42,0_ ;2
,$22,$49,$49,$49,$36,0_ ;3
,$18,$14,$12,$7F,$10,0_ ;4
,$2F,$49,$49,$49,$31,0_ ;5
,$3E,$49,$49,$49,$32,0_ ;6
,$61,$11,$09,$05,$03,0_ ;7
,$36,$49,$49,$49,$36,0_ ;8
,$26,$49,$49,$49,$3E,0],veri ;9
Thanks for taking the time helping...
