Customizing font style for running message...
Results 1 to 18 of 18
    Jun 2011
    Philippines
    Default Customizing font style for running message...
    Hi everyone,
    I'm trying to modify font style for the led matrix display(2x 8x8) please image below.
    and the following table is the font I'm using..
    lookup adres_sec,[$7C,$0A,$09,$0A,$7C,0_ ;A
                         ,$7F,$49,$49,$49,$36,0_      ;B
                         ,$3E,$41,$41,$41,$22,0_      ;C
                         ,$7F,$41,$41,$41,$3E,0_      ;D
                        ,$7F,$49,$49,$49,$41,0]veri  ;E
    As I understood there are hex values for each letter to turn on the individual leds in columns. Is it possible to change the style like bold and italic and is there a tool that will make this task easier? Sorry to ask this too but is it possible to display animated icon like pac-man? I appreciate any help.
    Thanks in advance,
    tacbanon
    Default Re: Customizing font style for running message... Dot matrix editor
    The excel file attached lets you create fonts in dot matrix, and outputs the binary code for each column. Here is a description: http://www.instructables.com/id/LED-...cs-Generator-/
    Here is one example of bold dot matrix font: http://www.identifont.com/show?1SN
    http://www.scalerobotics.com
    Jun 2011
    Philippines
    Hello scalerobotics,
    Thanks for sharing. I will try it and post here my output.
    tacbanon
    Bombay, India
    There is something called the dot factory http://www.pavius.net/2009/07/the-do...age-generator/ This is one very useful tool which allows you to convert any font/image from your PC.
    Jun 2011
    Philippines
    @Jerson
    Cool...thanks for the link.
    kind regards,
    tacbanon
    Jun 2011
    Philippines
    Hello, I'm back...I understand how to make the text message stop and scroll forward... can any one point out how can I make it scroll up.
    Bellow is the code I'm using...
    porta=0  :  portb=0  :  portc=0  :  portd=0
    trisa=0  :  trisb=0  :  trisc=0  :  trisd=0
    porte=0  : trise=0
    harf_reg var byte
    adres_sec var byte
    yinele var byte
    sutun_reg var byte[300]
    veri var byte
    yazi_reg var byte
    i VAR BYTE
    x var byte
    z var byte
    y var byte
    t var byte
    q var byte
    sure var byte
    yedek var byte
    CLEAR  :  portd=255:sure=200 :GOTO oku:
    oku:
    call yazi  : yazi_reg=yazi_reg+1  :  z=harf_reg
        for i=1 to z
            call yazi  : yazi_reg=yazi_reg+1  : call data_sec
            for y=0 to yinele
                call datalar
                sutun_reg[t]=veri  :  t=t+1
                adres_sec=adres_sec+1
            next y
        next i
    t=0
    goto gonder
    gonder:
    FOR Q=0 TO 5
        for i=0 to 15
            portb=sutun_reg[t]  :  t=t+1
            porta=i
            portc=%11111110:pauseus sure:portc=%11111111
        next i
        for i=0 to 15
            porta=i
            portc=%11111101:pauseus sure:portc=%11111111
        next i
        for i=0 to 15
            porta=i
            portc=%11111011:pauseus sure:portc=%11111111
        next i
         for i=0 to 15
            porta=i
            portc=%11110111:pauseus sure:portc=%11111111
        next i
        for i=0 to 11
            porta=i
            portc=%11101111:pauseus sure:portc=%11111111
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
            sutun_reg[i]=sutun_reg[i+1]
        next i
            sutun_reg[240]=yedek
    goto gonder
    yazi:
    lookup yazi_reg,[10,"HELLO WORLD"],harf_reg
    data_sec:
    select case harf_reg
    case "A"
    adres_sec=0  :  yinele=5  :  return
    case "B"
    adres_sec=6  :  yinele=5  :  return
    case "C"
    adres_sec=12  :  yinele=5  :  return
    case "D"
    adres_sec=18  :  yinele=5  :  return
    case "E"
    adres_sec=24  :  yinele=5  :  return
    case "F"
    adres_sec=30  :  yinele=5  :  return
    case "G"
    adres_sec=36  :  yinele=5  :  return
    case "H"
    adres_sec=42  :  yinele=5  :  return
    case "I"
    adres_sec=48  :  yinele=3  :  return
    case "i"
    adres_sec=52  :  yinele=3  :  return
    case "J"
    adres_sec=56  :  yinele=5  :  return
    case "K"
    adres_sec=62  :  yinele=5  :  return
    case "L"
    adres_sec=68  :  yinele=5  :  return
    case "M"
    adres_sec=74  :  yinele=5  :  return
    case "N"
    adres_sec=80  :  yinele=5  :  return
    case "O"
    adres_sec=86  :  yinele=5  :  return
    case "P"
    adres_sec=92  :  yinele=5  :  return
    case "Q"
    adres_sec=98  :  yinele=5  :  return
    case "R"
    adres_sec=104  :  yinele=5  :  return
    case "S"
    adres_sec=110  :  yinele=5  :  return
    case "T"
    adres_sec=116  :  yinele=5  :  return
    case "U"
    adres_sec=122  :  yinele=5  :  return
    case "ü"
    adres_sec=128  :  yinele=5  :  return
    case "V"
    adres_sec=134  :  yinele=5  :  return
    case "W"
    adres_sec=140  :  yinele=5  :  return
    case "X"
    adres_sec=146  :  yinele=5  :  return
    case "Y"
    adres_sec=152  :  yinele=5  :  return
    case "Z"
    adres_sec=158  :  yinele=5  :  return
    case " "
    adres_sec=164  :  yinele=5  :  return
    case "0"
    adres_sec=170  :  yinele=5  :  return
    case "1"
    adres_sec=176  :  yinele=3  :  return
    case "2"
    adres_sec=180  :  yinele=5  :  return
    case "3"
    adres_sec=186  :  yinele=5  :  return
    case "4"
    adres_sec=192  :  yinele=5  :  return
    case "5"
    adres_sec=198  :  yinele=5  :  return
    case "6"
    adres_sec=204  :  yinele=5  :  return
    case "7"
    adres_sec=210  :  yinele=5  :  return
    case "8"
    adres_sec=216  :  yinele=5  :  return
    case "9"
    adres_sec=222  :  yinele=5  :  return
    end select
    datalar:
     lookup adres_sec,[$05, $24, $74, $54, $7C, $78_      ;A
                       ,$7F,$49,$49,$49,$41,0_      ;E
                       ,$7F,$09,$09,$09,$01,0_      ;F
                       ,$3E,$41,$49,$49,$3A,0_      ;G
                       ,$7F,$08,$08,$08,$7F,0_      ;H
                       ,$41,$7F,$41,0_              ;I
                       ,$44,$7D,$44,0_              ;Ý
                       ,$20,$40,$41,$3F,$01,0_      ;J
                       ,$7F,$08,$14,$22,$41,0_      ;K
                       ,$7F,$40,$40,$40,$40,0_      ;L
                       ,$7F,$02,$04,$02,$7F,0_      ;M
                       ,$7F,$04,$08,$10,$7F,0_      ;N
                       ,$3E,$41,$41,$41,$3E,0_      ;O
                       ,$7F,$09,$09,$09,$06,0_      ;P
                       ,$3E,$41,$51,$61,$3E,0_      ;Q
                       ,$7F,$09,$19,$29,$46,0_      ;R
                       ,$26,$49,$49,$49,$32,0_      ;S
                       ,$01,$01,$7F,$01,$01,0_      ;T
                       ,$3F,$40,$40,$40,$3F,0_      ;U
                       ,$1E,$41,$01,$41,$1E,0_      ;Ü
                       ,$1F,$20,$40,$20,$1F,0_      ;V
                       ,$3F,$40,$30,$40,$3F,0_      ;W
                       ,$63,$14,$08,$14,$63,0_      ;X
                       ,$07,$08,$70,$08,$07,0_      ;Y
                       ,$61,$51,$49,$45,$43,0_      ;Z
                       ,$00,$00,$00,$00,$00,0_      ;Space
                       ,$3E,$51,$49,$45,$3E,0_      ;0
                       ,$42,$7F,$40,0_              ;1
                       ,$62,$51,$49,$45,$42,0_      ;2
                       ,$22,$49,$49,$49,$36,0_      ;3
                       ,$18,$14,$12,$7F,$10,0_      ;4
                       ,$2F,$49,$49,$49,$31,0_      ;5
                       ,$3E,$49,$49,$49,$32,0_      ;6
                       ,$61,$11,$09,$05,$03,0_      ;7
                       ,$36,$49,$49,$49,$36,0_      ;8
                       ,$26,$49,$49,$49,$3E,0],veri ;9
    This is the code for scrolling..
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 239
        next i
    Thanks in advance,
    tacbanon
    May 2006
    Del Rio, TX, USA
    What you want to do is shift the bits for each byte. Shift left to scroll up, shift right to scroll down.
    Scroll up: sutun_reg[i]=sutun_reg[i] << 1
    Scroll up: sutun_reg[i]=sutun_reg[i] >> 1
    Note that this does NOT carry the bits over, so after doing it 8 times, the display will be blank.
    If you want to display to "roll", then you would need to save the MSbit (or LSbit scrolling down) and then make it the LSbit (MSbit for scrolling down)after the shift.
    so, here's one way to do that (there is likely a more efficient way).
    temp_byte = sutun_reg[i]
    temp_bit = temp_byte.7
    temp_byte = temp_byte << 1
    temp_byte.0 = temp_bit
    sutun_reg[i] = temp_byte
    Jun 2011
    Philippines
    @ SteveB
    Thank you for the info and code..works awesome on my setup. However I was thinking of adding a little delay when (each letter are complete and reached the base of the matrix), before it'll scroll up again. I tried to add pauseus 200 in the code below but no effect..what do you think I'm missing?
    pauseus 200
    for i=0 to 30
            ;sutun_reg[i]=sutun_reg[i+1]
     next i
    Kind regards,
    tacbanon
    May 2006
    Del Rio, TX, USA
    "pauseus 200" is too quick, hardly a blink of an eye (it's 1/5 of a millisecond). Try "PAUSE 1000" This will be a 1 sec pause.
    May 2006
    Del Rio, TX, USA
    Here is a little more optimized code for the scroll up:
    temp_Byte = temp_Byte << 1
    temp_Byte.0 = STATUS.0
    It get's rid of the bit variable by taking advantage of the fact that the underlying assembly instruction moves the MSbit from the left shift into the "C" bit (which is bit 0) of the "STATUS" register.
    This will also work in a similar way for scrolling down:
    temp_Byte = temp_Byte >> 1
    temp_Byte.7= STATUS.0
    Jun 2011
    Philippines
    @SteveB
    Thanks again for the update...but sorry to bother you with this again, my text is scrolling downward at pauseus 200(fast) but in a certain point I want to pause it for about a 1 sec before it continue its process again.
    I tried to place pause within the program but not the exact output I'm trying to achieve...hope there is a way to do this.
    regards,
    tacbanon
    May 2006
    Del Rio, TX, USA
    You need to pause after 8 cycles, this should work:
        Scroll_Position = Scroll_Position + 1
        IF Scroll_Position = 8 THEN
            PAUSE 1000
            Scroll_Position = 0
            PAUSE 100
    It looks like it should go after the "NEXT Q"
    Jun 2011
    Philippines
    PAUSE 1000
    Scroll_Position = 0
    PAUSE 100
    The only problem now I'm having is that when it execute the "PAUSE 1000" it clears the matrix(blank) and prints again the letters after the pause.
    Kind regards,
    tacbanon
    May 2006
    Del Rio, TX, USA
    Please post the code you have now. That will help sort out the logic.
    I suspect the problem is that you need to execute the output code under "Gondor:" frequently enough to refresh the display, and the pause in interfering with the refresh.
    Jun 2011
    Philippines
    Quote Originally Posted by SteveB View Post
    I did try to find to place the code(you gave) and test it(by trial and error)...but having no luck. The following is the code I'm working on.
    porte=0  : trise=0
    harf_reg var byte
    adres_sec var byte
    yinele var byte
    veri var byte
    yazi_reg var byte
    i VAR BYTE
    x var byte
    z var byte
    y var byte
    t var byte
    q var byte
    Scroll_Position var byte
    temp_byte var byte
    temp_bit var bit
    sure var byte
    yedek var byte
    CLEAR  :  portd=255:sure=500 :GOTO oku:
    oku:
        for i=1 to z
            for y=0 to yinele
                call datalar
            next y
        next i
    t=0
    goto gonder
    gonder:
        IF Scroll_Position = 16 THEN   ; when this is TRUE it clears the matrix(turned off leds) for 1second
            Scroll_Position = 0
    FOR Q=0 TO 5
        for i=0 to 15
            porta=i
        next i
        for i=0 to 15
            porta=i
        next i
        for i=0 to 15
            porta=i
        next i
         for i=0 to 15
            porta=i
        next i
        for i=0 to 11
            porta=i
        next i
    t=0
    NEXT Q
    goto kaydir
    kaydir:
        yedek=sutun_reg[0]
        for i=0 to 30
        next i
    goto gonder
    yazi:
    lookup yazi_reg,[12,"HELLO WORLD"],harf_reg
    data_sec:
    case "A"
    case "B"
    case "C"
    case "D"
    case "E"
    case "F"
    case "G"
    case "H"
    case "I"
    case "i"
    case "J"
    case "K"
    case "L"
    case "M"
    case "N"
    case "O"
    case "P"
    case "Q"
    case "R"
    case "S"
    case "T"
    case "U"
    case "ü"
    case "V"
    case "W"
    case "X"
    case "Y"
    case "Z"
    case " "
    case "0"
    case "1"
    case "2"
    case "3"
    case "4"
    case "5"
    case "6"
    case "7"
    case "8"
    case "9"
    end select
    datalar:
                       ,$41,$7F,$41,0_              ;I
                       ,$44,$7D,$44,0_              ;Ý
                       ,$42,$7F,$40,0_              ;1
    Thanks for taking the time helping...
    regards,
    tacbanon
    May 2006
    Del Rio, TX, USA
    I can't test it out here, but I suspect that the problem with the longer pause is that the matrix wasn't being refreshed. So I modified a couple of things to control the flow of the program a little.
    I made a "Main_Loop" inside of which "gonder" is called as a GOSUB and the scrolling is controlled with a GOSUB to "kaydir". So both of those sections of code now terminate in a RETURN.
    This allows for the modified pause control. As you can see, the longer pause is multiple short pauses with a call to "gonder" in between to keep the display refreshed.
    Hope this helps.
        porte=0  : trise=0
        harf_reg VAR BYTE
        adres_sec VAR BYTE
        yinele VAR BYTE
        sutun_reg VAR BYTE[300]
        veri VAR BYTE
        yazi_reg VAR BYTE
        i VAR BYTE
        x VAR BYTE
        z VAR BYTE
        y VAR BYTE
        t VAR BYTE
        q VAR BYTE
        Scroll_Position VAR BYTE
        Pause_Cnt VAR BYTE
        temp_byte VAR byte
        temp_bit VAR bit
        sure VAR BYTE
        yedek VAR BYTE
        CLEAR
        portd=255 : sure=500
    oku:
        CALL yazi  : yazi_reg=yazi_reg+1  :  z=harf_reg
        FOR i=1 TO z
            CALL yazi  : yazi_reg=yazi_reg+1  : CALL data_sec
            FOR y=0 TO yinele
                CALL datalar
            NEXT y
        NEXT i
        t=0
    Main_Loop:
        GOSUB gonder
            For Pause_Cnt = 1 to 10         '<-- Change to control duration of pause after scroll, 10 = 1 sec, 20 = 2 sec, ...
                Pause 100
                GOSUB gonder
            Next Pause_Cnt
            Scroll_Position = 0
            GOSUB Kaydir
            PAUSE 100
        GOTO Main_Loop
    yazi:
        LOOKUP yazi_reg,[12,"HELLO WORLD"],harf_reg
    gonder:
        FOR Q=0 TO 5
            FOR i=0 TO 15
                porta=i
                portc=%11111110:PAUSEUS sure:portc=%11111111
            NEXT i
            FOR i=0 TO 15
                porta=i
                portc=%11111101:PAUSEUS sure:portc=%11111111
            NEXT i
            FOR i=0 TO 15
                porta=i
                portc=%11111011:PAUSEUS sure:portc=%11111111
            NEXT i
            FOR i=0 TO 15
                porta=i
                portc=%11110111:PAUSEUS sure:portc=%11111111
            NEXT i
            FOR i=0 TO 11
                porta=i
                portc=%11101111:PAUSEUS sure:portc=%11111111
            NEXT i
            t=0
        NEXT Q
    kaydir:
        yedek=sutun_reg[0]
        FOR i=0 TO 30
        NEXT i
    data_sec:
        SELECT CASE harf_reg
        CASE "A"
            adres_sec=0  :  yinele=5  :  RETURN
        CASE "B"
            adres_sec=6  :  yinele=5  :  RETURN
        CASE "C"
            adres_sec=12  :  yinele=5  :  RETURN
        CASE "D"
            adres_sec=18  :  yinele=5  :  RETURN
        CASE "E"
            adres_sec=24  :  yinele=5  :  RETURN
        CASE "F"
            adres_sec=30  :  yinele=5  :  RETURN
        CASE "G"
            adres_sec=36  :  yinele=5  :  RETURN
        CASE "H"
            adres_sec=42  :  yinele=5  :  RETURN
        CASE "I"
            adres_sec=48  :  yinele=3  :  RETURN
        CASE "i"
            adres_sec=52  :  yinele=3  :  RETURN
        CASE "J"
            adres_sec=56  :  yinele=5  :  RETURN
        CASE "K"
            adres_sec=62  :  yinele=5  :  RETURN
        CASE "L"
            adres_sec=68  :  yinele=5  :  RETURN
        CASE "M"
            adres_sec=74  :  yinele=5  :  RETURN
        CASE "N"
            adres_sec=80  :  yinele=5  :  RETURN
        CASE "O"
            adres_sec=86  :  yinele=5  :  RETURN
        CASE "P"
            adres_sec=92  :  yinele=5  :  RETURN
        CASE "Q"
            adres_sec=98  :  yinele=5  :  RETURN
        CASE "R"
            adres_sec=104  :  yinele=5  :  RETURN
        CASE "S"
            adres_sec=110  :  yinele=5  :  RETURN
        CASE "T"
            adres_sec=116  :  yinele=5  :  RETURN
        CASE "U"
            adres_sec=122  :  yinele=5  :  RETURN
        CASE " "
            adres_sec=128  :  yinele=5  :  RETURN
        CASE "V"
            adres_sec=134  :  yinele=5  :  RETURN
        CASE "W"
            adres_sec=140  :  yinele=5  :  RETURN
        CASE "X"
            adres_sec=146  :  yinele=5  :  RETURN
        CASE "Y"
            adres_sec=152  :  yinele=5  :  RETURN
        CASE "Z"
            adres_sec=158  :  yinele=5  :  RETURN
        CASE " "
            adres_sec=164  :  yinele=5  :  RETURN
        CASE "0"
            adres_sec=170  :  yinele=5  :  RETURN
        CASE "1"
            adres_sec=176  :  yinele=3  :  RETURN
        CASE "2"
            adres_sec=180  :  yinele=5  :  RETURN
        CASE "3"
            adres_sec=186  :  yinele=5  :  RETURN
        CASE "4"
            adres_sec=192  :  yinele=5  :  RETURN
        CASE "5"
            adres_sec=198  :  yinele=5  :  RETURN
        CASE "6"
            adres_sec=204  :  yinele=5  :  RETURN
        CASE "7"
            adres_sec=210  :  yinele=5  :  RETURN
        CASE "8"
            adres_sec=216  :  yinele=5  :  RETURN
        CASE "9"
            adres_sec=222  :  yinele=5  :  RETURN
        END SELECT
    datalar:
        LOOKUP adres_sec,[$05, $24, $74, $54, $7C, $78_      ;A
        ,$41,$7F,$41,0_              ;I
        ,$44,$7D,$44,0_              ;
        ,$42,$7F,$40,0_              ;1
    Jun 2011
    Philippines
    Hello SteveB,
    Your'e awesome...works great as you expected.
    I will build to extend the length of led matrix display and post here the results.
    tacbanon
    May 2006
    Del Rio, TX, USA
    Glad it worked!
