16f84A to 16f628A
Results 1 to 9 of 9
    May 2009
    Default Re: 16f84A to 16f628A
    You have not added Cmcon=7. Put it at the start of the program
    Sep 2009
    grahamg Yes I added cmcon = 7
    @ device PIC16F628A, HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF
    TrisA = %00000000
    PortA = %00000000
    TrisB = %00000001
    PortB = %00000000
    cmcon = 7
    Digit Var Byte
    Time Var Word
    Tcon Con 245
    Time = Tcon
    Imp Var Word
    Imp = 0
    RPM Var Word
    RPM = 0
    OPTION_REG = %10000011
    TMR0=5
    INTCON = %10110000
    Pause 1000
    EEPROM 80,[83,46,84,32,69,108,101,99,116,114,111,110,105,99,1 15]
    May 2008
    Italy
    RA4 is an open collector pin so it will not turn from zero to 5 volts as all the digital pins.
    If all you need is to turn your led on & off, then connect your 330 ohms resistor to 5 volts and RA4 pin to junction from led and 330 ohms resistor.
    Remember then when pin is on your led will be off.
    Cheers
    Al.
    Sep 2009
    Friend aratti yes you have absolute right
    Now works also the PortA.4 yessssssssssssssssssss
    Thank you very much
