16f84A to 16f628A
Results 1 to 9 of 9
    May 2009
    Default Re: 16f84A to 16f628A
    Change first line to @ Device PIC16f628A HS_OSC, WDT_OFF, PWRTE_ON, CP_OFF
    That in theory is all that should be needed.
    Quote Originally Posted by grahamg View Post
    nope, 16f628 has comparators too add cmcon = 7
    Sep 2009
    I made the changes and work henceforth in 16F628
    I thank you for the precious help
    Sep 2009
    I made an addition to the code
    The PortA.3 working properly, the PortA.4 but did not work always remains at a low level
    What I make error, please help
    @ device PIC16F84A, HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF
    TrisA = %00000000
    PortA = %00000000
    TrisB = %00000001
    PortB = %00000000
    Digit Var Byte
    Time  Var Word
    Tcon Con 245
    Time = Tcon
    Imp   Var Word
    Imp = 0
    RPM   Var Word
    RPM = 0
    OPTION_REG = %10000011
    TMR0=5
    INTCON = %10110000
    Pause 1000
    PortB = $7e  '-
    PortA.0 = 0: PortA.1 = 0: PortA.2 = 1
    Pause 1000
    PortB = $7e  '-
    PortA.0 = 0: PortA.1 = 1: PortA.2 = 0
    Pause 1000
    PortB = $7e  '-
    PortA.0 = 1: PortA.1 = 0: PortA.2 = 0
    Pause 1000
    ' ------------------------- [ Interrupt ] -------------------------
    On Interrupt Goto myint
    ' ------------------------- [ Main ] -------------------------
    Digit = RPM Dig 0
    GoSub Look
    Pause 4
    PortB = $FE
    Digit = RPM Dig 1
    GoSub Look
    Pause 4
    PortB = $FE
    if RPM < 100 then
    Pauseus 300
    Goto Main
    Digit = RPM Dig 2
    GoSub Look
    Pause 4
    PortB = $FE
    ' ----------------------- [ HIGH RPM ] -----------------------
    if RPM >= 60 then
    high PortA.3
    low PortA.3
    if RPM >= 70 then
    high PortA.4
    low PortA.4
    Goto Main
    Disable
    Myint:
    if intcon.1=1 then
    Imp = Imp + 1
    INTCON.1 = 0
    if intcon.2=1 then
    Time = Time - 1
    if Time = 0 then
    Time = Tcon
    RPM = Imp * 60 / 10
    Imp = 0
    TMR0=5
    intcon.2=0
    Resume
    Enable
    Look:
    LookUp Digit, [$80, $F2, $48, $60, $32, $24, $04, $F0, $00, $20], PortB
    May 2009
    You have not added Cmcon=7. Put it at the start of the program
    Sep 2009
    grahamg Yes I added cmcon = 7
    @ device PIC16F628A, HS_OSC, WDT_OFF, PWRT_ON, PROTECT_OFF
    TrisA = %00000000
    PortA = %00000000
    TrisB = %00000001
    PortB = %00000000
    cmcon = 7
    Digit Var Byte
    Time Var Word
    Tcon Con 245
    Time = Tcon
    Imp Var Word
    Imp = 0
    RPM Var Word
    RPM = 0
    TMR0=5
    INTCON = %10110000
    Pause 1000
    EEPROM 80,[83,46,84,32,69,108,101,99,116,114,111,110,105,99,1 15]
    May 2008
    Italy
    RA4 is an open collector pin so it will not turn from zero to 5 volts as all the digital pins.
    If all you need is to turn your led on & off, then connect your 330 ohms resistor to 5 volts and RA4 pin to junction from led and 330 ohms resistor.
    Remember then when pin is on your led will be off.
    Cheers
    Al.
