18F2431 Learning Curve
Results 1 to 21 of 21
    Default Re: 18F2431 Learning Curve
    Some will disagree, but I have never trusted the programmer to set the configs.
    What version of PBP are you running?
    Jan 2011
    Sydney, Australia
    Ver 3.0.1.4
    How should I manually set the configs and/or which configs are critical for my simple application?
    I went back to the LCD test program and noticed that I do get two lines of text appearing BUT the timing is way out of kilter - maybe by a factor of 10 or 20?
    I am pretty sure I have a clock issue. I don't have any crystals to drop in place but will try to get some tomorrow. I will also re-try the Blinky LED program and reduce the time between toggles to see if I can get something happening...
    Cheers
    Barry
    VK2XBP
