On Interrupt
Results 1 to 8 of 8
Thread: On Interrupt
    Mark's Avatar
    Mark Guest
    I'm using a 16F628 and RB0
    here's something to play with.
        ' RB0 interrupt
        ' File name : RB0.bas
        ' Company : Mister E
        ' Programmer : Steve Monfette
        ' Date : 03/05/2005
        ' Device : PIC16F628
        '    PIC setting
             ' Using MPASM to compile the code to target device
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _LVP_OFF & _BODEN_ON
             ' Internal Oscillator
             ' Enable watch dog timer
             ' Enable power up timer
             ' Disable MCLR pin
             ' Disable low voltage programming
             ' Enable brown out detect
        '    Hardware definition
             TRISB = %00000001   ' RB0 as input, other as output
                                 ' Push button between RB0 & ground
        '    I/O Alias definition
             RB0LED              var   PORTB.6
             MainLoopLED         var   PORTB.7
        '    Interrupt Definition
             OPTION_REG = 0      ' Enable pull-up on PORTB
                                 ' RB0 interrupt on falling edge
             INTCON = %10010000  ' Enable Global interrupt
                                 ' Enable RB0 interrupt
             on interrupt goto RB0Interrupt
        '    Variable definition
             Delay              var word
        '    MainLoop
    Start:
         ' Let's do some led blink on RB.7
        Toggle mainloopled
        for Delay = 1 to 500 ' delay loop 500ms
            pause 1          ' using 1 ms delay to avoid latency
            next             '
        goto start           ' do it forever
        Disable Interrupt
    RB0Interrupt:
                ' RB0 interrupt subroutine
                ' will toggle RB6 state everytime we get an interrupt
        Toggle rb0led
        while PORTB.0 = 0                ' wait untill RB0 go high
        wend
        pause 50                         ' debounce delay
        INTCON.1 = 0                     ' Reset RB0 int flag
        resume                           ' return to main loop
        Enable interrupt
    and another way by polling interrupt flag.
        ' RB0 interrupt
        ' Date : 03/05/2005
        '    PIC setting
             ' Disable MCLR pin
             RB0LED              var   PORTB.6
             Delay              var word
        '    MainLoop
    Start:
        Toggle mainloopled
            if INTCON.1 then    ' test RB0 interrupt flag
               rb0led=RB0LED ^1 ' toggle RB0LED status
               INTCON.1=0       ' reset interrupt flag
            next
    Mark's Avatar
    Mark Guest
    Question
    Thanks Steve
    This is great - these examples give me 2 ways to use the interrupt.
    I will try these out - but before I do I have a question about the first example using the On Interrupt.
    I assume we need to disable the interrupt in the handler so we don't get caught in a endless loop - is that correct ?
    Should we have the "disable interrupt" inside the RBOinterrupt routine at the start ?
    Mark's Avatar
    Mark Guest
    Thumbs up
    I have tested both examples and they both produce the same function.
    They compile into 108 vs. 103 words.
    I modified the code and found the answers to my questions - There is no substitue for testing.
    I don't have an exact application in mind yet so it is good to know both.
    Do you have a preference for one technique or a simple way to describe the trade offs between the two?
    Thanks for your help.
    Quote Originally Posted by Mark
    Since every project are different, need are also different. I don't prefer one to another, just need to know what i need and how much time i want to spend on. But more than often i'll use ON INTERUPT.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
