Musical sounds
Results 1 to 3 of 3
Thread: Musical sounds
    Sep 2010
    Las Vegas, NV
    Default Musical sounds
    Ladies and Gents,
    I'll ask the question first then expand. Why will the first program, ImperialMarch.bas, play the notes only one time through and requires a reprogram for the notes to be played again and the second, This works, play the notes without having to reprogram the chip? I know the first is set up to loop and the second is triggered but why does the first require a reprogram to play the music?
    Background: Someone asked if I could write a program simulating the sounds of the Imperial Death March using a PIC. I had a12F683 a piezo speaker and some time and this is what I came up with. Other than the speaker hooked up to gpio.2 there is a resistor pulling gpio.5 high or low as needed and a resistor pulling gpio.3 high. The first program is just a loop, or it should be, and the second is triggered by a switch.
    The first program, imperailmarch.bas, will play the sounds when programmed then won't play them again until the chip is reprogrammed. It will, if left alone long enough, intermittently make a scratchy sound like a modems initial negotiation for speed.
    '*  Name    : ImperialMarch.BAS                                 *
    ' This version will only play one time through and stop.
    clear
    @ device mclr_off
    @ device bod_off
    @ device fcmen_off
    @ device ieso_off
    @ device intrc_osc_noclkout
    @ device pwrt_on
    @ device protect_off
    define osc4
    osccon = %01100111
    ansel = 0 ' set all ports digital
    cmcon0 = 7 ' comparators off
    adcon0 = 0 ' adc off
    '------------------------variables
    c con 91 ' converting values to frequency and musical notes
    a con 105
    dsH con 112
    f con 99
    fH con 114
    fsH con 115
    gs con 104
    cs con 92
    d con 95
    ds con 96
    notta con 97
    e con 98
    aH con 117
    cH con 109
    eH con 113
    gsh con 116
    gH con 115
    aS con 106
    b con 108  ' end of music
    speaker var gpio.2
    '-------------------------------------------finally the program
    goto playsong
    goto main ' do it forever
    playsong:
    sound speaker, [a,50]
    sound speaker, [f,40]
    sound speaker, [cH,20]
    sound speaker, [f,43]
    sound speaker, [a,65]
    pause 150
    sound speaker, [eH,40]
    sound speaker, [fh,30]
    sound speaker, [cH,12]
    sound speaker, [gS,40]
    sound speaker, [f,33]
    sound speaker, [a,55]
    pause 150
    end ' supposed to put an end to the program
    The second program, This works.bas, will play the notes anytime I drag GPIO.5 low.
    '*  Name    : thisworks.BAS                                     *                                  *
    ' This version will replay the march each time gpio.5 is brought low.
    ' It draws less than 40uA typically but if allowed to rest long enough
    ' it will wander up to around 200uA.  Why it changes I also don't understand.
    clear
    @ device mclr_off
    @ device bod_off
    @ device fcmen_off
    @ device ieso_off
    @ device pwrt_on
    define osc4
    osccon = %01100111
    c con 91 ' converting values to frequency corresponding to musical notes
    a con 105
    dsH con 112
    f con 99
    fH con 114
    fsH con 115
    gs con 104
    cs con 92
    d con 95
    ds con 96
    notta con 97
    e con 98
    aH con 117
    cH con 109
    eH con 113
    gsh con 116
    gH con 115
    aS con 106
    speaker var gpio.2
    '-----------------------------begin program
    If gpio.5 = 0 then
    sound speaker, [a,40,a,40,a,40,f,30,cH,12,a,40,f,33,cH,12,a,55]
    pause 150
    sound speaker, [eH,40,eH,40,eH,40,fh,30,cH,12,gS,40,f,33,cH,12,a,55]
    nap 5
    If anyone can expound upon why one works and the other doesn't I'd appreciate your input.
    Sep 2009
    Default Re: Musical sounds
    You have GOTO playsong, and on end of playsong is RETURN.
    Return can be used ONLY if you have GOSUB or CALL label.
    Replace GOTO playsong with GOSUB playsong, them try it.
    Sep 2010
    Las Vegas, NV
    Doh! What's that saying about the forest and the trees. Thanks.
