Thanks Guys,
I probably confused you a bit.
The 1000mA unit is the one already built which i wanted to upgrade to 5amp later. It used a .1 ohm resistor in the positive output which I removed and linked out. I then added a .47 in the ground leg.
I then intended to design and build a multi function charger/desulphator unit which would probably be capable of 10amp.
I would be quite happy with 10mA resolution on any of them. It's just that the counts I'm getting from the ADC just don't seem right anyway.
I have another new 16f877 which i will test out.
I mentioned the advertised unit because of it's specs and it's circuit. 3W .47ohm resistor in ground leg with 10amp measurement ? Capable of recalibration to greater amps?
Probably a catchpa in the instructions when you get it.
Rob
