Change a variable to the opposite?
Results 1 to 11 of 11
    Nov 2009
    London
    Default Re: Change a variable to the opposite?
    That is an "exclusive OR" (XOR) with a byte of 00001111. So when you input 00001001, it will return 00000110.
    Here is the truth table on page 79 of the manual.
    A    B   A ^ B
    0    0      0
    0    1      1
    1    0      1
    1    1      0
    If only A or only B is 1, then result is 1.
    The ^ operator is commonly used to invert selected bits:
    This would my my answer as well.
    Sep 2007
    Doh! Since you posted the truth table, you are correct that I did not RTFM. Before my original post I tried to but didn't know where to look. Now I do and since most of the code uses binary I used:
    BCD_In = BCD_In ^ %11111111
    Thank you for the pointers and help!
    Is BCD value 9 the only value that needs translation? Could you actually need a BCD to grey code translation?
    Tim Barr
    If your variable is always going to be 4 bits, the complement would be got by variable(comp) = 15-variable.
    Anand
