urgent help receiving ASCII char from serial port
Results 1 to 3 of 3
    Jun 2012
    Smile urgent help receiving ASCII char from serial port
    hi,
    i'm facing a problem that can't be solved at least for me
    i receive serial input from weight meter head
    the input in the form shown in this image ASCII Characters
    this picture shows the input from weight meter at the left
    and the lcd output for the code attached
    it's 2 kilogram but the lcd shows 20 and sometimes it shows 00000000 values instead since it store values randomly without index or char to start from
    the problem is that i need to read the values after "=" equal ascii character
    i need a way to store array of ascii's input let's say 10 input's until it reaches the charachter "=" so that i can use DIG to extract the values and display it in 7 segment display instead of lcd.
    note: the data sheet of the weight meter head shows that the input is
    decimal,<ASCII> i don't now what this is suppose to mean !!
    but when i tried another code it gives me reversed values on the lcd if i tried to store values as string of 10 char
    and then used dig to extract them and displayed them at lcd with DEC before each char extracted
    i.e
    it shows
    decimal 35 for ascii 5
    decimal 84 for ascii 0
    but when i put weight more than 9 it shown only the values coresspondes to the right part of the number
    so if the weight was 10 it shows 84
    another thing to say is that 84 is the reverse of dec equavelent for ascii 0
    the code i'm using
    '* Name : 7SEG-MULTIPLEXING.BAS *
    '* Author : [ Eng. Mohammad Aqel ] *
    '* Date : 11/9/2007 *
    DEFINE OSC 20
    ' Set LCD Data port
    DEFINE LCD_DREG PORTD
    ' Set starting Data bit (0 or 4) if 4-bit bus
    DEFINE LCD_DBIT 4
    ' Set LCD Register Select port
    DEFINE LCD_RSREG PORTD
    ' Set LCD Register Select bit
    DEFINE LCD_RSBIT 0
    ' Set LCD Enable port
    DEFINE LCD_EREG PORTD
    ' Set LCD Enable bit
    DEFINE LCD_EBIT 1
    ' Set LCD bus size (4 or 8 bits)
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    ' Set command delay time in us
    DEFINE LCD_COMMANDUS 2000
    ' Set data delay time in us
    DEFINE LCD_DATAUS 50
    INCLUDE "modedefs.bas"
    ' Set baud rate
    DEFINE HSER_SPBRG 129 ' 2400 Baud @ 0.17%
    datain var byte
    SerialData var byte
    COUNTER VAR WORD
    COUNTER1 VAR BYTE
    COUNTER2 VAR BYTE
    ASCII VAR BYTE
    Ser var byte[20]
    A var byte[5]
    B var byte[5]
    i var byte
    j var byte
    ADCON1 = 6 'PORTA AND e DIGITAL
    TRISC = %10000000 ' PORTC.7 is the RX input
    ' PORTC.6 is the TX output
    TRISB=0
    TRISD=0
    TRISA=0
    PORTD=$FF
    PORTB=0
    A0 var word
    A1 var word
    A2 var word
    A3 var word
    A4 var word
    A5 var word
    A6 var word
    A7 var word
    A8 var word
    A9 var word
    A10 var word
    b0 var byte
    num var byte
    Hex_input var byte
    A_D_A VAR BYTE [20]
    MAIN:
    'hserin [DEC3 ser] ' Receive string of 10 characters
    For i = 0 to 19
    HSERIN [DEC3 ser(i)]
    Next i
    'for j=0 to 19
    'if ser.0[i] = "=" then
    'LCDOUT $fe,$80,dec j
    'endif
    'pause 100
    'next j
    A0=Ser dig 0
    A1=Ser dig 1
    A2=Ser dig 2
    A3=Ser dig 3
    A4=Ser dig 4
    A5=Ser dig 5
    A6=Ser dig 6
    A7=Ser dig 7
    A8=Ser dig 8
    A9=Ser dig 9
    A10=Ser dig 10
    LCDOUT $fe,$80, # a0, # A1, # A2, # A3, # A4, # A5, # A6, # A7, # A8, # A9, # A10
    'goto MAIN
    eND
    Feb 2014
    Default Re: urgent help receiving ASCII char from serial port
    Sep 2010
    Las Vegas, NV
    I'm not the best in serial comms but it appears to me you've got the HSERIN command incorrectly formatted.
    I also think you haven't declared the ser variables.
    I also think you've got code that's over 7 years old. I wonder why it's important to fix now?
    We need to know what chip you're using, what version of PBP you're using and what you've done to try and fix the problem.
    I think when they say the output is in ASCII you have to use a table to decode output. According to this link http://www.asciitable.com/for the output to be say 25 you'd have an output like 50,53 in decimal or 32, 35 hex. So you need to read the book on how to make that display the correct numbers.
    I hope I haven't led you astray.
