Can anyone explain why I am getting this message" Error[112]c:\pbp\pbppic14.lib 2945 missing operator".
Well actually 4 lines of the same error but each with a different number at the end!
First line is 2945 then 3052,3061 and 3069.
All I was doing was playing around with someones example of 3x A to D on a pic, and changed the actual isplay lines slightly to suit my LCD which is 2x20 instead of 16.
I compilee ok at first and successfully programmed the pic16F872 and all was well.
Then I changed a bit of the code after the $fe in the LCD part and got the strange errors.
This is the code below, can anyone explain the errors. The commented out parts are just bits I was trying when I got the code, otherwise the code is as was!
Thanks Al
Code:' Define LCD pins Define LCD_DREG PORTB Define LCD_DBIT 0 1 Define LCD_RSREG PORTB Define LCD_RSBIT 4 Define LCD_EREG PORTB Define LCD_EBIT 5 Define LCD_LINES 2 TRISA = %00001011 ' Allocate variables x var byte y var byte z var byte ADCON1 = 4 ' Set PortA 0, 1, 3 to A/D inputs Low PORTB.6 ' LCD R/W line low (W) Pause 100 ' Wait for LCD to start Goto mainloop ' Skip subroutines ' Subroutine to read a/d converter getad: PAUSEUS 50 ' Wait for A/D channel acquisition time ADCON0.2 = 1 ' Start conversion WHILE ADCON0.2 ' Wait for it to complete WEND Return ' Subroutine to get pot x value getx: ADCON0 = $41 ' Set A/D to Fosc/8, Channel 0, On Gosub getad x = ADRESH Return ' Subroutine to get pot y value gety: ADCON0 = $49 ' Set A/D to Fosc/8, Channel 1, On Gosub getad y = ADRESH Return ' Subroutine to get pot z value getz: ADCON0 = $59 ' Set A/D to Fosc/8, Channel 3, On Gosub getad z = ADRESH Return mainloop: Gosub getx ' Get x value Gosub gety ' Get y value Gosub getz ' Get z value Lcdout $fe, 1, "x=", #x, " y=", #y, " z=", #z ' Send to LCD 'Lcdout $fe, 1,"TEST" 'Lcdout $fe,$80,"x=", #x ' Send to LCD 'Lcdout $80, 1 + 10, "y=", #y' Send to LCD 'Lcdout $fe, $C0, "z=", #z' Send to LCD 'Lcdout $fe, $C0 + 10, "v="' Send to LCD Pause 100 ' Do it about 10 times a second Goto mainloop ' Do it forever End
