Can anyone explain why I am getting this message" Error[112]c:\pbp\pbppic14.lib 2945 missing operator".
Well actually 4 lines of the same error but each with a different number at the end!
First line is 2945 then 3052,3061 and 3069.
All I was doing was playing around with someones example of 3x A to D on a pic, and changed the actual isplay lines slightly to suit my LCD which is 2x20 instead of 16.
I compilee ok at first and successfully programmed the pic16F872 and all was well.
Then I changed a bit of the code after the $fe in the LCD part and got the strange errors.
This is the code below, can anyone explain the errors. The commented out parts are just bits I was trying when I got the code, otherwise the code is as was!
Thanks Al
' Define LCD pins
Define  LCD_DREG        PORTB
Define  LCD_DBIT        0                                                         1
Define  LCD_RSREG       PORTB
Define  LCD_RSBIT       4
Define  LCD_EREG        PORTB
Define  LCD_EBIT        5
Define  LCD_LINES       2
TRISA = %00001011
' Allocate variables
x       var     byte
y       var     byte
z       var     byte
        ADCON1 = 4              ' Set PortA 0, 1, 3 to A/D inputs
        Low PORTB.6             ' LCD R/W line low (W)
        Pause 100               ' Wait for LCD to start
        Goto    mainloop        ' Skip subroutines
' Subroutine to read a/d converter
getad:
        PAUSEUS 50              ' Wait for A/D channel acquisition time
        ADCON0.2 = 1            ' Start conversion
        WHILE ADCON0.2        ' Wait for it to complete
        WEND
' Subroutine to get pot x value
getx:
        ADCON0 = $41            ' Set A/D to Fosc/8, Channel 0, On
        Gosub getad
        x = ADRESH
' Subroutine to get pot y value
gety:
        ADCON0 = $49            ' Set A/D to Fosc/8, Channel 1, On
        Gosub getad
        y = ADRESH
' Subroutine to get pot z value
getz:
        ADCON0 = $59            ' Set A/D to Fosc/8, Channel 3, On
        Gosub getad
        z = ADRESH
mainloop:
        Gosub   getx            ' Get x value
        Gosub   gety            ' Get y value
        Gosub   getz            ' Get z value
        Lcdout $fe, 1, "x=", #x, " y=", #y, " z=", #z ' Send to LCD
        'Lcdout $fe, 1,"TEST"
        'Lcdout $fe,$80,"x=", #x     ' Send to LCD
        'Lcdout $80, 1 + 10, "y=", #y' Send to LCD
        'Lcdout $fe, $C0, "z=", #z' Send to LCD
        'Lcdout $fe, $C0 + 10, "v="' Send to LCD
        Pause   100             ' Do it about 10 times a second
        Goto    mainloop        ' Do it forever
