If then
Results 1 to 12 of 12
Thread: If then
    Nov 2007
    sri lanka
    Default If then
    dear all
    TRISB=%00000000
    PORTB=%00000000
    DEFINE HSER_TXSTA 20h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 2400
    DEFINE HSER_SPBRG 25
    DEFINE HSER_CLROERR 1
    TRISB=%00000000
    PORTB=%00000000
    trisd=%00001111
    portd=%00000000
    GSM_CHECK:
    portb=%11110000
    HSEROUT ["AT",13]
    HSERIN 5000, GSM_CHECK, [WAIT("OK")]
    pause 200
    PORTb=%00000000
    BEGIN:
    high PORTB.6
    if PORTD.0 = 1 then SEND_SMS0
    IF PORTD.1 = 1 then SEND_SMS1
    if PORTD.0 = 0 then SEND_SMS2
    IF PORTD.1 = 0 then SEND_SMS3
    PAUSE 1000
    LOW PORTB.6
    GOTO BEGIN
    SEND_SMS0:
    HIGH PORTB.7
    HSEROUT ["at+cmgs=",34,"0719099xxx",34,13]
    PAUSE 1000
    HSEROUT ["unit ,1, triped",26]
    HSERIN 5000, BEGIN, [WAIT("OK")]
    LOW PORTB.7
    SEND_SMS1:
    HIGH PORTB.6
    PAUSE 1000
    HSEROUT ["unit,2, triped",26]
    LOW PORTB.6
    SEND_SMS2:
    HIGH PORTB.5
    PAUSE 1000
    HSEROUT ["unit ,1, syncronus",26]
    LOW PORTB.5
    SEND_SMS3:
    HIGH PORTB.4
    PAUSE 1000
    HSEROUT ["unit ,2,syncronus",26]
    LOW PORTB.4
    this coode not working.some body can help me
    Default Re: If then
    Good question! What PIC are you using? Which part of your code doesn't work? What kind of trouble shooting have you tried?
    http://www.scalerobotics.com
    Nov 2007
    sri lanka
    Default Re: If then
    portd.0 and portd.1 inputs get syncronus breaker lcosed and open cotact point.its repeat send sms.i can't anderstand how to write.
    Nov 2007
    sri lanka
    Default Re: If then
    i get inputs my syncronous breaker closed and open point.if portd 0=1 then send sms0 it repeat .my pic is 16f877a.
    thank you
    Default Re: If then
    For the RX port, you would want to set TRISC to %10000000
    Nov 2007
    sri lanka
    Default Re: If then
    rx and tx working.send "AT" modam reply "OK"
    now case this program
    please send me sample
    Default Re: If then
    I received a PM defining the problem a little better:
    dear sir
    can u help me this project
    my modem ok
    send AT
    reply OK
    this program send sms repitly how to stop it
    thank you
    So, you only want to send sms on change of state for portd.0 or portd.1 ?
    port d.0
    Here are some untested modifications to your code. It should test for a change condition on portd.0 and portd.1. I know you said you only wanted d.0, but you can always remove the rest.
    TRISB=%00000000
    PORTB=%00000000
    PortDStatus var byte        ' variable for storing status of portd
    TRISB=%00000000
    PORTB=%00000000
    trisd=%00001111
    portd=%00000000
    GSM_CHECK:
    portb=%11110000
    HSEROUT ["AT",13]
    pause 200
    PORTb=%00000000
    'get initial status
    PortDStatus.0 = PORTD.0
    PortDStatus.1 = PORTD.1
    BEGIN:
    high PORTB.6
    if PORTD.0 != PortDStatus.0 then            'sensed change in PORTD.0
        pause 10                                'debounce 10 ms
        PortDStatus.0 = PORTD.0                 'save new status for PORTD.0
        if PORTD.0 = 1 then
            gosub SEND_SMS0                     'send new status report
        else                                    'PORTD.0 = 0
            gosub SEND_SMS2
    if PORTD.1 != PortDStatus.1 then            'sensed change in PORTD.1
        pause 10
        PortDStatus.1 = PORTD.1                 'save new status for PORTD.1
        IF PORTD.1 = 1 then
            gosub SEND_SMS1
        else                                    'PORTD.1 = 0
            gosub SEND_SMS3
    PAUSE 1000
    LOW PORTB.6
    GOTO BEGIN
    SEND_SMS0:
    HIGH PORTB.7
    PAUSE 1000
    LOW PORTB.7
    SEND_SMS1:
    HIGH PORTB.6
    PAUSE 1000
    LOW PORTB.6
    SEND_SMS2:
    HIGH PORTB.5
    PAUSE 1000
    LOW PORTB.5
    SEND_SMS3:
    HIGH PORTB.4
    PAUSE 1000
    LOW PORTB.4
    Nov 2007
    sri lanka
    Default Re: If then
    thank you i will try it
    Nov 2007
    sri lanka
    Default Re: If then
    thank you sir
    it's really work
    thank u again
    ruwan.
    Nov 2007
    sri lanka
    Default Re: If then
    how to send multiple number for same sms
    Default Re: If then
    Nov 2007
    sri lanka
    Default Re: If then
    HSEROUT[ "AT+CMGS="07190xxxx4071909xxx5"
    but this code don't work
    please ex plane this code sample
