Fixing percent sign when posting code.
Results 1 to 19 of 19
    Default Re: Fixing percent sign when posting code.
    Due to popular demand, Lester has changed everyone's settings to use the standard editor as default. The wysiwyg editor ("what you see is what you get" .... well almost!) can still be selected by those that want it.
    The wysiwyg editor was cutting off the first two bits after each %. I think there were a couple of other odities as well. If you still with to use the wysiwyg editor, it is still available. Just click on settings, select general settings, and mark the box for the editor of your choice. If you want to keep the standard editor, of course, you don't have to do anything.
    http://www.scalerobotics.com
    It seems that the WYSIWYG setting has no affect.
    The "Quick Reply" editor is always "Source Mode", and there's no button to switch to WYSIWYG.
    But if you click the "Go Advanced" button, the editor is still in Source Mode, but there's a button for WYSIWYG.
    It doesn't seem to matter which way the setting is.
    Well, except for the "Basic Editor".
    You don't want to select the Basic Editor.
    So all in all, it works for me.
    Oops, I guess you're right. Currently you don't really get a choice, it just looks like you do.
