This has been mentioned several times now but I'll bring it up again since it's still a big problem.
When posting code between code tags and including binary numbers like ADCON=101011 the forum tends to remove the percent sign and some of the digits. It doesn't happen all the time:but it sure does happen a lot - for example here, here and here (and that's just the last couple days) but, for example, NOT in this post.Code:ADCON=%101011 'same as above
What is going on? This issue really needs to be looked into IMHO.
EDIT: Look it happend to me in this post. The thing is that at first it was fine, then I went into EDIT the post and after "reposting" it i was messed up.
