Measuring temperature with a PIC
Results 1 to 7 of 7
    Apr 2007
    Pennsylvania, USA
    Default Re: Measuring temperature with a PIC
    I like the LM34DZ (same as above but calibrated in Fahrenheit. Cost $2.00-$2.50 available from mouser. Easy to use with a PIC and there is plenty of code floating around the forums to use.
    http://www.mouser.com/ProductDetail/...eSEq67kjn80%3d
    Shawn
    USA - Arizona
    LM35 or LM34 - nice and easy; minimal math on PIC to translate voltage to temperature.
    DS18B20 - simple digital interface; almost no math at all on the PIC
    Either choice should suffice: LM3x if you want to use analog input into PIC's ADC, DS18xx if you want to use digital interface.
