Home made PCB's
Results 1 to 23 of 23
Thread: Home made PCB's
    stevlena, A laserjet printer uses powered toner as a medium that runs thru a fuser to set it. An InkJet uses liquid ink as the medium..
    Sep 2009
    For those that like the iron on method but don't like the iron part of it - Consider getting a laminator!
    You have to buy specific ones though, notably ones made by GBC as these are much like a laser printer fuser where the heat is applied to the rollers. Most laminators have heat plates before plain rollers.
    I use one sold at Kmart here in aus - costs about $30 and is faaar superior to using a clothes iron.
    Feb 2005
    Kolkata-India
    Default PulsarProFx
    I use the Pulsar toner transfer paper with the GBC laminator. The only problem is for 2.4mm PCB thickness it becomes a pain to get the board through the laminator. I make upto A4 size boards. www.pulsarprofx.com
    I got a cheaper alternative toner transfer paper from ebay:
    http://cgi.ebay.com/Heat-Toner-Trans...#ht_2405wt_734
    They work great and being thinner than the pulsar paper gives smoother rolls through the laminator. The GREEN TRF from pulsar which seals of the toner is an absolute must if you need quality pcbs and thin lines.
    Sougata
  1. Insteon Home Automation Software Development Kit
    By Stuartk in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2013, 18:52
  2. Anyone willing to etch some PCBs?
    Last Post: - 16th December 2009, 19:30
  3. Home made optical rencoder issues
    By Elnino in forum mel PIC BASIC Pro
    Last Post: - 27th November 2009, 23:17
  4. Made Hall Sensor (magnet peek up )
    By jetpr in forum mel PIC BASIC Pro
    Last Post: - 31st January 2005, 02:23
  5. How made a webserver wit a pic
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 29th September 2004, 05:55
