Relation between Pressure and weight
Results 1 to 8 of 8
    Nov 2009
    London
    Default Re: Relation between Pressure and weight
    HenrikOlsson, thanks a lot for your help.
    Just one last question to confirm my understanding.
    So, if I have two different diameters for two cylinders, I should calculate the weight individually for each and add it together towards the end to get the total weight.
    Yes, or calculate the total area and multiply that by the pressure.
    If you have one 100mm and one 50mm cylinder you have an effective area of (50*50*pi/100) + (25*25*pi/100) = 78.5+19.6 = 98.1cm²
    Just remember that if the cylinders aren't of the same size (diameter) they won't share the load equally (one will "push" more than the other at any given pressure).
