Maths help please
Results 1 to 3 of 3
    Jan 2010
    Default Maths help please
    Hi, I have one MCP3204 connected to my my 877A. I am getting the 12bit reading fine. The sensor is hooked to a load sensor. My problem is that how Can I get the exact load from the reading. My load sensor is for 14tonns. So 4096 reading for 14 tonns. Each increment is for 3.41Kg. My problem is dealing with decimal numbers, can someone advise on how to deal with calculations like this ??????
    Default Re: Maths help please
    Take the reading from your A/D and multiply it by 341. If your a/d sensor value is 1, then you will get 341 for 3.41 kg. You can set your lcd display to show this in the format of 3.41 if you like. Or you can divide the result by 100 and just end up with with 3 kg (no decimals).
    http://www.scalerobotics.com
    How about
    kg=raw_value */ 875
    It's not perfect but is it enough?
    Or you might try
    dummy = raw_value * 3419
    kg = DIV32 1000
    or perhaps
    hg = DIV32 100
    HSEROUT["Result: ", #hg/10, ".", #hg//10, "kg", 13]
    If you have PBP2.60 or newer and you're able to use LONGS then there are other possibillities as well.
