Convert Rotary Encoder Code from 16F628A to 16F1825
Results 1 to 28 of 28
    Default Convert Rotary Encoder Code from 16F628A to 16F1825
    I did some prototyping with the 16F628A but now I need to move my code to another PIC which as at least two CCPs so I can send out HPWM commands to 2 motors (but use 1 rotary encoder to control the duty cycle). The 16F628A only has 1 CCP so after some trial and error on the Microchip site to find an appropriate PIC I settled on the 16F1825 which has 4 CCPs (more than I need, I know).
    Now that I'm converting the code I'm wondering if I've really messed up. In the 16F628A data sheet it says that RB4/5 pins can be used as interrupt-on-pin change and indeed when I connect the A/B pins of the rotary encoder to these two and using the code below with Darrel's interrupt plug-in all works fine:
    '*  Name    : Nacelle_Motors_16F628A.BAS                        *
    '*  Author  : Ross A. Waddell                                   *
    '*  Notice  : Copyright (c) 2010 RAW Studios                    *
    '*  Date    : 05/18/2012                                        *
    '*  Notes   : Motor control for TOS E engines                   *
    '---------Initialization--------
    DEFINE OSC 20            ' set oscillator 20Mhz
    ' Device Fuses
    @ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _BODEN_ON & _LVP_OFF & _CP_OFF & _CPD_OFF
    CMCON    = 7    	 ' Turn off comparators
    TRISA    = %00000000 ' Make all PortA pins output
    TRISB    = %00110000 ' Make PortB pins 4-5 input
    Old_Bits       VAR BYTE
    New_Bits       VAR BYTE
    RotEncDir      VAR BIT   ' 1=CW, 0=CCW
                             ' Rot Enc pin A connected to PortB.5;
                             ' Rot Enc pin B connected to PortB.4
    Old_RPM        VAR BYTE
    I              VAR BYTE
    ' SETUP YOUR LCD HERE!!!
    ;Define LCD_DREG PORTA
    ;Define LCD_DBIT 0
    ;Define LCD_RSREG PORTA
    ;define LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 7            ' Use PortB.7 as the Enable (E) bit since PortB.3
                                 ' on the 16F628A is the one-and-only HPWM output
    ;define LCD_BITS 4
    ;define LCD_LINES 2
    ;define LCD_COMMANDUS 2000
    ;define LCD_DATAUS 50
    '---------Includes----------
    INCLUDE "EE_Vars.PBP"       ' Requires MPASM assembler
                                ' Go to "View > Compile and Program Options..."
                                ' On "Assembler" tab, check "Use MPASM"
                                ' (no need to change any of the default settings)
                                ' --> copy file to PBP main folder (i.e. c:\pbp)
    MotorRPM VAR BYTE  :  @  EE_var  _MotorRPM, BYTE, 50
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
                                 ' --> copy both files to PBP main folder
                                 ' (i.e. c:\pbp)
    INT_LIST  macro    ; IntSource,         Label,  Type, ResetFlag?
            INT_Handler    RBC_INT,  _Rot_Encoder,   PBP,  yes
        INT_CREATE     ; Creates the interrupt processor
    @ INT_ENABLE   RBC_INT     ;RB Port Change Interrupt
    ' Set default values
    Old_Bits = PORTB & (%11110000)
    Old_RPM = MotorRPM
    LCDOUT $FE, 1
    PAUSE 1000
    rpmAdj CON 20       ' PWM cycle seems to be "higher" than HPWM, so need
                        ' to reduce PWM cycle max to be less than HPWM cycle value
    ' Spin up motor to saved value of _MotorRPM
    IF MotorRPM > rpmAdj Then
        FOR i = 0 to (MotorRPM - rpmAdj)
            PWM PortB.3, I, 100
        NEXT I
    EndIf
    ' Begin background HPWM
    GOSUB motorhpwm
        IF MotorRPM <> Old_RPM Then
            Old_RPM = MotorRPM
            GOSUB motorhpwm
    @ EE_write_var _MotorRPM        ; save the new number to EEPROM
        EndIF
        LCDOUT $FE, 2, "MotorRPM: ", #MotorRPM, "   "
        pause 10
        GOTO Main
    motorhpwm:
        HPWM 1, MotorRPM, 20000 ; Tried 245 Hz but it made the motor too loud.
                                ; Supposedly, anything above 20kHz is above
                                ; human hearing
    '---[RBC - interrupt handler]---------------------------------------------------
    Rot_Encoder:
        New_Bits = PORTB & (%11110000)
        IF (New_Bits & %00110000) = (Old_Bits & %00110000) Then DoneRotEnc
        RotEncDir = New_Bits.5 ^ Old_Bits.4
        IF RotEncDir = 1 Then
            ; CW rotation - increase speed but only to a max of 255
            IF MotorRPM < 255 then MotorRPM = MotorRPM + 1
        Else
            ' CCW rotation - decrease speed to a min of 0
            IF MotorRPM > 0 Then MotorRPM = MotorRPM - 1
        EndIF
    DoneRotEnc:
        Old_Bits = New_Bits
    @ INT_RETURN
    Now that I've got the 16F1825 chip, though, and I'm reading through the data sheet I don't see similar info about any of the PortA/C pins in terms of providing interrupt-on-pin change, so here's my question: have I picked the wrong chip? All I really want is one very similar to the 16F628A but with two CCPs. If I still can use the 16F1825, what does this code become and what pins can I use (presuming RA4/5 are for the external oscillator & RC3/5 are for the HPWM)?
    Default Re: Convert Rotary Encoder Code from 16F628A to 16F1825
    Should work....from section 13 (Interrupt-On-Change) of the datasheet:
    The PORTA pins can be configured to operate as Interrupt-On-Change (IOC) pins. On the PIC16(L)F1829 devices, the PORTB pins can also be configured to operate as IOC pins.
    Thanks Henrik, but the 14 pin 16F1825 schematic doesn't show PortB pins.
    No, but it does show PortA pins and according to the quote from the datasheet PortA has IOC.
    Thanks Henrik - I didn't catch the part about PortB on chip 16F1829.
    I've got the code converted to work with a 16F1825 but I had to add the following to the p16F1825.inc file in MPASM:
    CCPTMRS          EQU  H'029E'
    CCPTMRS0         EQU  H'029E'
    Can anyone tell me why? All I'm trying to do is use HPWM on CCP3 with the following config/code:
    ANSELA   = %00000000
    ANSELC   = %00000000
    TRISA    = %00000011     ' Make PortA pins 0-1 input for rotary encoder
    TRISC    = %00000000     ' Make all pins on PortC output
    HPWM 3, 97, 20000
    Until I added the line above in the p16F1825.inc MPASM file, I got this compile error:
    Error[113] c:\pbp\pbppi14e.lib 2089 : Symbol not previously defined (CCPTMRS0)
    In the version history for PBP3 ... http://support.melabs.com/content/29...ersion-History
    One of the bug fixes listed is ... Fixed HPWM compile error for Enhanced Mid-Range parts in which CCPTMRS0 doesn't exist.
