I keep revisiting this project, then parking it & then resurrecting it...and guess what I've just resurrected it!
I seek to derive the frequency of a plucked guitar note so I can do lots of funky frequency related stuff to the signal
I've presently got a PIC (16f1828) a comparator setup & I'm looking at the number of counts timer1 has incremented between each DT comparator interrupt.
for now I'm usiing a sig gen with a sine wave (yes I realise a guitar note is way more complicated...but I'll cross that bridge blah blah)
Anyway, by & large it's working OK.....the TMR1 count jitters about a bit, but it's close enough. but what I'm seeing is that with some frequencies the count jitters *way* too much.
For example, heres a stable-ish(!) timer1 count for 1khz into the PIC comparator.....
3208
3203
3194
3183
3161
3163
3163
3156
3150
3152
3148
3141
3139
Ok so it's a little jittery but in percentage terms the jitter is still fairly low, but look what happens when I then feed 800hz into the same same setup....
4955
180
4982
205
5012
176
4936
176
4963
183
4988
207
5001
176
4936
176
4957
...the Timer1 count between comparator interrupts is all over the shop!
Can anyone enlighten me why this might be happening?
here's the interrupt SETUP......
Code:ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler CMP2_INT, _CMP2_Interrupt, PBP, YES endm INT_CREATE ; Creates the interrupt processor ENDASM CMP2_Interrupt: ' COMPARATOR2 INTERRUPT. @ INT_DISABLE CMP2_INT hserout [dec TMR1,13,10] TMR1=0 @ INT_ENABLE CMP2_INT @ INT_RETURN
Is my approach wrong here?
Basically I want this type of sequence...
1. Guitar string plucked - PIC detects this (envelope detector)
2. PIC waits about 0.5s (to let the complex harmonics drop out)
3. PIC then attemps to detect frequency for a period of about 0.3s
4. Use a look up table for number of counts
5. Go do stuff with the outcome!
Now step 4 (go do stuff) I don't need help on - it's step 3 that I'm wondering what the best approach would be?
