50Khz PWM
Results 1 to 4 of 4
Thread: 50Khz PWM
    Feb 2004
    Michigan, USA
    Default 50Khz PWM
    18F2550
    48MHz
    I have set up CCP1 to provide a 50KHz PWM using the code below. However I need to use a 10bit number for the duty cycle. How do I implement that? Do I change
    high_duty=(PWM_SIGNAL>>2)
    to
    high_duty=(PWM_SIGNAL)
    and also
    low_duty=(PWM_SIGNAL<<6)
    to
    low_duty=(PWM_SIGNAL<<8)
     PWM_SIGNAL = 255CCP1CON = 111100
    PR2 = 239
    high_duty=(PWM_SIGNAL>>2)        'high 6 bits in CCPR1L
          low_duty=(PWM_SIGNAL<<6)         'low two bits for CCP1CON
          low_duty=(low_duty>>2)           'shift back to CCP1CON<5:4>
          low_duty.3=1                     'PWM configuration bit
          low_duty.2=1                     'PWM configuration bit
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    Thanks.
    Default Re: 50Khz PWM
    You won't get a full 10bit resolution at that frequency but it'll be pretty close. But you do
    Duty VAR WORD
    Duty = 500  'Or whatever
    CCP1CON.4 = Duty.0
    CCP1CON.5 = Duty.1
    CCPR1L = (Duty >> 2)
    Feb 2004
    Michigan, USA
    Thanks Henrik. I implemented your changes as shown below but this seems to stop the duty cycle at 25% or 256. It then rolls over to 0.
    CCP1CON = %00111100
    PR2 = 239
          low_duty.4=0                     'PWM configuration bit
          low_duty.5=1                     'PWM configuration bit
    CCPR1L=high_duty
    CCP1CON = $0C
    T2CON = 4
    Feb 2004
    Michigan, USA
    I had PWM_SIGNAL defined as a BYTE not WORD.
    Solved.
