Thanks.
Just for clarification, the top "from PIC" is actually the PIC GND pin? The resistor we've been talking about is 2.2 ohms, not 2.2K as shown?
Thanks.
Yes, 1 of those lines goes to the PIC ground and the other goes directly to the output pin.
That should be 2.2Ohm sorry.
It does not state if your AC supplies are Peak or RMS but a reasonable guess is that the maximum swing your output can make is going to be under 12V.
The input impedance of the circuit will be between 33K and about 50K depending on frequency. Overall gain of the circuit is about 20-ish It would help to know what the signal looks like coming out of the PIC, but a single pole filter is not really going to get rid of enough garbage for you, especially if there is a fair amount of 44 KHz stuff around. It would certainly be better than nothing. However, a couple RC stages should be able to knock it down enough to not be an issue for your amplifier and power dissipation at least.
But first, for your original question, redo your power calculation with a maximum of 12V and a maximum frequency of 20 KHz to see how much power will be in the resistor. Also, that's 12 V P-P. For sizing the resistor, it would make more sense to use RMS - call it 4.2V
OK, let's see how this goes.
Frequency = 20,000Hz
1/(2*PI*frequency*cap value) gives 36.2Ohms for the cap.
36.2 + 2.2 = 38.4Ohms total accross the resistor and capacitor.
30VA 12-0-12 supply gives 2.5A max.
I'm basing the current through the resistor on the difference between the resistor/cap and the speaker. I would say roughly 17% of the current should go through the resistor/cap.
2.5 * 0.17 = 0.425 through the resistor/cap.
0.425 * 0.425 * 2.2 = 0.4W.
0.4W is much better. If I used a 470nF as the datasheet suggests then I work it out to be 1.4W though which still seems a little high but it's still much better than before.
I'm not quite sure how RMS works with current. Using 4.2V would give around 7A using my calculation. That doesn't seem right at all.
I just noticed one of your previous edits. Yes, designing analog circuits is fun but only because I get to see an explosion![]()
Treat RMS like DC. And don't forget to fix the frequency. If you are using 22nF, then that's about 330-ish ohms at 20 KHz. I think you should be seeing more like 1/2 amp than 7 amps.
I'm still not sure about the RMS. I'm Calculating the max current by dividing 30VA by the volts.
I just found my cable for connecting to the PC and I'm shocked. With the current setup I managed to get to the point where it started clipping and hold it there without anything blowing up.
I added a 10nF cap between the pot's wiper and ground which took a little of the sharpness off the high parts and it's sounding perfect. Now the problem is how to do that with the PIC. I will try connecting my scope up to see if I can get anything useful out of it.
How would multiple RC stages work? Couldn't the same effect be achieved using a single RC with different values?
