OK, I now have a PIC18F2431 with acounter set up on Timer1 and a time base set up on Timer0.
The counter was pretty straight forward but i have a few questions regarding the operation of Timer0
1/. Timer Pre-Load
Timer0 is a 16 bit timer which gives an output as it rolls over from $FFFF to 0.
An 8MHZ clock speed will provide one instruction every 500ns. For a 100Hz time base (10ms period) I would need 20000 instruction cycles (20000 x 500ns = 10ms).
A free running timer wiith no pre-load would roll over every 65536th cycle so to achieve a 20000 cycle roll over I need to pre-load the timer with 65536 - 20000 = 45536.
All good - nice clean theory however, a 45536 pre-load results in ~50Hz time base!
Here is my code:
I know my internal oscillator is operating at 8MHz because my LCDOUT commands work properly.Code:#CONFIG CONFIG OSC = IRCIO CONFIG FCMEN = ON CONFIG IESO = OFF CONFIG PWRTEN = ON CONFIG BOREN = ON CONFIG BORV = 42 CONFIG WDTEN = OFF CONFIG WDPS = 512 CONFIG WINEN = OFF CONFIG PWMPIN = OFF CONFIG LPOL = HIGH CONFIG HPOL = HIGH CONFIG T1OSCMX = OFF CONFIG MCLRE = ON CONFIG STVREN = ON CONFIG LVP = OFF CONFIG DEBUG = OFF CONFIG CP0 = ON CONFIG CP1 = ON CONFIG CP2 = ON CONFIG CP3 = ON CONFIG CPB = OFF CONFIG CPD = OFF CONFIG WRT0 = OFF CONFIG WRT1 = OFF CONFIG WRT2 = OFF CONFIG WRT3 = OFF CONFIG WRTC = OFF CONFIG WRTB = OFF CONFIG WRTD = OFF CONFIG EBTR0 = OFF CONFIG EBTR1 = OFF CONFIG EBTR2 = OFF CONFIG EBTR3 = OFF CONFIG EBTRB = OFF #ENDCONFIG ' Set up interrupt routine INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler TMR0_INT, _ISR, PBP, yes endm INT_CREATE ; Creates the interrupt processor ENDASM @ INT_ENABLE TMR0_INT ; Enable Timer 0 Interrupts ' Define LCD registers and bits Define LCD_DREG PORTB Define LCD_DBIT 4 Define LCD_RSREG PORTA Define LCD_RSBIT 1 Define LCD_EREG PORTA Define LCD_EBIT 2 Define LCD_BITS 4 Define LCD_LINES 2 ' Set up Internal Oscillator @ 8MHz DEFINE OSC 8 OSCCON = %01110010 ' Internal oscillator, 8MHz ' Set up Timer0 T0CON = %00001000 ' Timer off ' 16 bit ' Internal clock ' Prescaler not assigned T0CON.7 = 1 ' Start Timer0 ' Set up I/O Ports ANSEL0 = 0 ' No analogue input, all digital TRISA = 0 ' ALL PORTA as outputs PORTA = 0 ' All outputs low TRISB = 0 ' ALL PORTB as outputs PORTB = 0 ' All outputs low TRISC = 0 ' Set PORTC as output PORTC = 0 ' All outputs low Pause 100 LCDOUT $FE,1," Baztronics " Pause 100 TMR0_Reload CON 55750 ' Reload value for ~100Hz interrupt frequency at 8MHz, prescaler 1:1 TMR0_Temp VAR WORD ' Temporary variable use for reloading the timer LED1 VAR PortC.2 Main: Pause 100 Goto Main ' This is the interrupt routine for the TMR0 interrupt. ISR: T0CON.7 = 0 ' Stop timer TMR0_Temp.LOWBYTE = TMR0L TMR0_Temp.HighByte = TMR0H ' Get current "time" TMR0_Temp.LOWBYTE = TMR0L ' TMR0_Temp.HighByte = TMR0H TMR0_Temp = TMR0_Temp + TMR0_Reload ' Add reload value to get correct interval TMR0L = TMR0_Temp.LOWBYTE TMR0H = TMR0_Temp.HIGHBYTE ' Move result back to timer TMR0L = TMR0_Temp.LOWBYTE ' TMR0H = TMR0_Temp.HIGHBYTE T0CON.7 = 1 ' Start timer Toggle LED1 @ INT_RETURN
Can anyone explain why the time base is not as predicted?
2/. TMR0L and TMR0H
The datasheet states that "TMR0H is not the high byte of the timer/counter in 16bit mode, but is actually a buffered version of the high byte of Timer0" and that it "is not directly readable nor writable."
It goes on to explain that "TMR0H is updated wth the contents of the high byte of TMR0 during a read of TMR0L" The same conditions apply for write operations.
The way I understand this, I must read the TMR0L first, this transfers the buffered data to the high byte of TMR0H and THEN I can read the high byte directly.
Obviously I have mis understood the operation as this does not work.
The only way I can get the timer to provide a stable time base is to read TMR0L twice and TMR0H once OR read TMR0H twice and TMR0L once.
Would someone be able to describe how/why the low and high bytes of TMR0 should be read/written?
Cheers
Barry
VK2XBP
