Hi Barry,
It depends on how you are driving the bridge.
If I understand correctly you're feeding the MOSFETs (thru their drivers) from two of the PWM generators - both in complementary mode, ie four outputs from the PIC. PWM0 & PWM1 are feeding the left leg while PWM2 & PWM3 are feeding the right leg of the bridge (or the other way around). Is that correct so far?
Now, what do you do when you want the motor to turn clockwise (or counter clockwise)?
Do you set one of the PWM generators to 0% (effectively turning on the LOW side switch of that leg) and then apply the output of the PID-filter to the other PWM generator? If you ARE doing this then the motor IS shorted thru the lower two switches during the off-period of the PWM cycle (and, obviously, when the dutycycle of both generators are 0). This will brake the motor but won't regenerate (I think), ie it won't feed energy back to the powersupply. Instead, the energy will be absorbed by the armature resistance of the motor, the rds-on of the MOSFET, wiring, connectors and so on. If this IS what you're doing please note that the braking current this generates does not flow thru your current sense resistor. If the motor is spinning, generating 200V of EMF and you suddenly set both dutycycle registers to 0% the motor will be shorted thru the bottom two switches, how much current will that result in?
The other option is to run the bridge in what's called locked antiphase mode. In this mode you typically use a single PWM generator and drive one diagonal pair of switches with the "true" output and the other diagonal pair with the inverted output.
In this mode the bridge switches between the two diagonal pairs during the PWM cycle. When the dutycycle is 50% each diagonal pairs are "on" for 50% of the PWM cycle resulting in a net current of zero thru the motor. When "forward torque" is to be generated the "balance" is shifted so that one diagonal pair is "on" for a larger amount of time during the PWM cycle resulting in "actual" current thru the motor. In this case the motor will brake AND regenerate when the voltage produced by the bridge is LESS than the motor produced by the EMF of the motor. The motor will never be shorted out.
Phew, I hope I got that right....don't quote me though!
