incPID Routine - Help Needed
Results 1 to 40 of 64
Threaded View
  1. #8
    Default Re: incPID Routine - Help Needed
    Just an observation. The shaft encoder is ready made or are you using an opto interrupter with a disc etc?
    If the latter is the case be sure that it can detect pulses of 5.5KHz.
    I think it is better to use directly the train pulse and feed a timer, TMR1 for example.
    Better accuracy, less parts.
