PBP hardware oriented?
Results 1 to 8 of 8
    IMHO simulation tools are just toys. not much. I really prefer to have all my parts on a board to see the real operation in a real environement.
    But if you feel better to use something that gives you those toys, PBP is not the one you need. As i know/suspect PROTON gives those toys.
    mytekcontrols's Avatar
    mytekcontrols Guest
    Question I read it to...
    Originally Posted by Acetronics
    And did you see PBP manual ???
    May be it's time to read it ...
    I have one of the latest manuals which I ordered with my last upgrade, and I can't find any command or reference that states usage with the I2C or SPI hardware. Alain can you please respond and tell us what you are talking about?
    I too would love to see full support of any hardware peripheral functions by PBP.
    Posted many times on many thread... At this time PBP don't handle the MSSP module. if you want it now, you build it. well as now. I also hope that one day that option will be considered by Melabs. Not because SHIFTIN/SHIFTOUT/I2CREAD/I2CWRITE and others don't work properly... just because they don't use the internal ressources and the possible max speed.
    mytekcontrols Guest
    My main reason for wanting it has to do with easing the load on the program, and giving you a somewhat multi-tasking aspect. If I recall correctly there are built-in data buffers associatted with the hardware I2C. So it would seem that you could just load the buffer with a PBP command and then take off and do something else while the buffer is sent. Of course the buffer is very short, but still it seems like their would be advantages to the person that uses PBP because they don't like, or know how to program in assembly.
    Even better still would be if a future version of PBP would give the option of implementing recieve buffers for the serial and I2C routines. Something that would be able to operate in the background as an interrupt, and set a flag that could be occasionally polled by the PBP code.
    I luckly do know how to write assembly interrupts, so for me there are other ways to skin the cat (opps! I would NEVER do such a thing, and my cat still has all of his fur), but for some folks it is still beyond there comfort level, and is probably the reason they bought a Basic Compiler in the first place.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Hardware Interrupts and PBP
    By manumenzella in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 09:16
  3. Replies: 1
    Last Post: - 23rd December 2006, 11:38
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 04:16
