Memsic 2125 code?
Results 1 to 25 of 25
    Mar 2011
    Los Angeles, California
    Default Re: Memsic 2125 code?
    Hi Walter and everyone!
    Okay so I corrected the code in the Read_X_Force as the "return" caused the program to stop and the formula said to divide by 8 not multiply. With the digital scope I was able to know the exact timing of the pulses. The catch is that the devide puts out a pulse reading from 1810 to 3132 so the formula does not work. I attached word files to show the code, what the pulse measurement is at level, what the code does with level and what the code does with the device at +90 degrees (up) and -90 degrees (down). The original code uses 10 ms and the scope says it is 9.9 ms so rather than x2 I made it x20 to divide by 99. The problem with the code seems to be with the 50% duty cycle value? Please let me know what you think. Thanks, Ed
    Pulse Widths.doc
    Tilt Code.doc
    UP.doc
    Level.doc
    Down.doc
    Quote Originally Posted by Ramius View Post
    Ed, are you refering to the place in the formula where there was a /12.5% ? If so, this is simplified by *8.
    See this part of the previously attached document:
    "Since our T1 time is in microseconds and there are 1000 microseconds in a millisecond, we need
    to multiply the T2 value and 0.5 by 1000 to adjust the equation. This makes the math easy for the
    Stamp and gives us an output with a resolution of 0.001g. Finally, the divide by 12.5% part of the
    equation is converted to multiplying by eight ( 1 / 0.125 = 8 ) – we couldn't ask for a value much
    more convenient than that."
    http://www.scalerobotics.com
