Re: DMX512 SPEC OF data format of WAVEFORM
Originally Posted by
longpole001
DMX512 appear to be well below par and waist full, even when used in wired app for the data sent , has no checking, no end of packet byte and high over head when less than 512bytes use , cos you have to know you not getting 512 bytes , not that you missed some and would fill the air with less than usefull retries to achieve an effect result.
I think you may have misinterpreted what DMX512 was designed to do. Its was specifically designed for control of lighting in a theatrical/club environment where lights are constantly changing. It is only wasteful if not properly configured.
The data packet consists of a header byte followed by a byte for each of the channels in order. As such it doesnt need any addressing info, the receiving device merely detects the header byte then count until the number of bytes received matches its configured address. There doesnt need to be a end of packet byte because there is a break in transmission between packets. The recieving device looks for the break, then header then counts.
Many DMX controllers use less than 512 channels, 54 or 192 channels being quite common. A 54 channel controller only sends 55 bytes per packet and as such can refresh lights about 9 times faster than a controller that addresses an entire universe.
DMX has been around a long time now and Im pretty sure that it would have been superceeded if it was as flakey as you appear to think it is. Good cable and correct termination makes for a robust system in what is often a very electrically noisy environment.
Keith
www.diyha.co.uk
www.kat5.tv
